I PAD
Posted: Nov 7th, '13, 14:06
I know we may not be ready to give up our marine electronics yet but technology is getting better!
Nav App
https://itunes.apple.com/us/app/inavx-m ... mpt=uo%3D4" onclick="window.open(this.href);return false;
Waterproof Case
http://www.lifejacketcase.com/waterproof-ipad-case/" onclick="window.open(this.href);return false;
And now.......Transducer
http://vexilar.com/products/index.php?prodNum=SP200" onclick="window.open(this.href);return false;
Re: I PAD
Posted: Nov 7th, '13, 14:16
by SteveM
Peter, I've seen guys at the dock that have built in recessed areas for the iPad display, which then shows the data. They can also take it out of the dash and use it over their onboard network. Pretty slick.
Steve
Re: I PAD
Posted: Nov 7th, '13, 14:25
The problem with iPads (as well as iPhones) is that using the GPS chews up the battery as if there's no tomorrow… Add WiFi or Bluetooth (for wireless speakers) and you'll get maybe a couple of hours out of a full battery… And I'm speaking from experience… And I have yet to see a waterproof case that has the power line built-in...
Re: I PAD
Posted: Nov 7th, '13, 15:06
As I understand it the case I put the link for has a waterproof USB charging port that is not on their website yet. But should be available soon.
Re: I PAD
Posted: Nov 7th, '13, 19:29
by ZeroCavity
Best waterproof case :
http://www.lifeproof.com/en/ipad/?path=TopNav" onclick="window.open(this.href);return false;
Re: I PAD
Posted: Nov 7th, '13, 20:43
by Capt.Frank
That's the case my wife has so far so good. Anyone have a Bluetooth GPS for one yet. Wife was wondering about having one so she could see where we were from the cabin.
Re: I PAD
Posted: Nov 8th, '13, 02:54
Capt.Frank wrote:That's the case my wife has so far so good.
I have their case for my iPhone and it works perfectly… However, even that case is NOT waterproof when the charging cable is connected…
Capt.Frank wrote:Anyone have a Bluetooth GPS for one yet.
What version IPad does your wife have? IIRC, some (all?) of the WiFi versions do not have a GPS built-in. However, all G3 versions have a GPS built in. Possibly you already have the GPS built-in?!...
Re: I PAD
Posted: Nov 8th, '13, 09:40
by jackryan
Here is a bluetooth GPS receiver that I have heard works great. It can supply gps data to up to 5 devices at a time:
http://bad-elf.com/pages/be-gps-2200-detail" onclick="window.open(this.href);return false;
the same company also sells a gps receiver for the iphone. This is great for use offshore where you don't have cell coverage.
http://bad-elf.com/pages/be-gps-1008-detail" onclick="window.open(this.href);return false;
This is a good iPhone GPS app that my brother gave me recently:
http://www.isailgps.com" onclick="window.open(this.href);return false;
Re: I PAD
Posted: Nov 8th, '13, 10:24
I know it was said already but some of the newer version IPAD and IPHONE have a built in GPS that does not require cell service, blue tooth or WIFI
Re: I PAD
Posted: Nov 8th, '13, 13:44
by jackryan
Peter,
I've been using it in the marine environment, and it works fairly well, but I've had some problems with the accuracy of the internal GPS while offshore out of sight of cell towers. It usually happens while moving, so maybe it's loosing lock on the satellites. Also, I'm using this on an iPhone, not an iPad. The Ipad may have a more robust antenna. Although the answer is geared toward aviation, they address this in their FAQ's:
I already have GPS in my iPad (cellular) or iPhone. Why do I need the Bad Elf GPS?
The GPS receiver inside these 3G devices works great on the ground, particularly when in range of a 3G cellular network. The internal Apple GPS is a real GPS receiver, but the size of the device and its proximity to other antennas limits performance. To get around this, these internal GPS receivers use Assisted GPS data from cellular network towers to obtain a faster signal lock. The GPS works even if you don’t pay for monthly 3G service from a wireless provider.
These internal GPS receivers were not designed for aviation, so most pilots report that they lose lock, or have trouble maintaining a lock, when at altitudes greater than 2,000 AGL or when operating at high speeds. Under such conditions, lock times can take 5-20 minutes, if you get lock at all. In contrast, the Bad Elf GPS delivers better performance with rock solid WAAS GPS locks at altitudes up to 60K feet and at speeds up to 1,000 mph. Acquire a satellite lock in as little as 30-45 seconds and observe accuracy to 2.5 meters.
The Bad Elf GPS delivers...
Twice the accuracy (2.5m vs 5m)
Ten times the sampling rate (10Hz vs. 1Hz)
More sensitivity, enabling use in urban canyon environments!
For those of you that have repowered your 31 with the larger engines, this should help you maintain GPS lock as you approach speeds of 1000 mph
Re: I PAD
Posted: Nov 8th, '13, 14:17
Good to know Jack thanks..
Re: I PAD
Posted: Nov 8th, '13, 14:31
by TailhookTom
jackryan wrote:Peter,
Great information, thanks Capt. -- btw, I won't have to worry about losing lock with my engines, unless I turn them up to 11.
Tom
Re: I PAD
Posted: Jan 13th, '14, 15:36
Just to keep this thread up to date
There is now a waterproof USB charging port. Although it looks to only be water proof when not charging.
http://www.lifejacketcase.com/purchase/ ... t-built-in" onclick="window.open(this.href);return false;
Re: I PAD
Posted: Jan 13th, '14, 16:24
The way I see it is that the iPad is contained in a water proof environment while being charged… But, the port that serves as the power in port isn't waterproof… Good for use on the flybridge of my 48' Bert but useless on my 20' bow rider and my 17' jet boat…
