v-berth hatch
Posted: Jan 18th, '07, 21:16
by thereheis
i am trying to replace the hinge on the v-berth overhead hatch. the ones that was on there are gone ,does anyone have a pic or info on what kind they are ???are they just a plain butt hinge ?????or will a piano hinge work ???any help out there ???
phil
Posted: Jan 18th, '07, 21:42
Phil,
I've got the one from Patrick's boat sitting here & it won't be going back on... Come get it.
v-berth hatch
Posted: Jan 19th, '07, 00:03
by thereheis
all i need is the hinge???? will be out of pcket for a couple of days///
Posted: Jan 19th, '07, 07:41
Phil,
I've got the whole hatch assembly, but if all you need is hinges, piano hinges are what you want...
v-berth hatch
Posted: Jan 19th, '07, 08:12
by thereheis
capt. pat are those hinges pop- riveted on or screwed onto the hatch ?
phil
Posted: Jan 19th, '07, 09:10
The hatch is 3/4" wood, painted white & hinges screwed in. Teak drop trim on the front edge.
v-berth hatch
Posted: Jan 19th, '07, 09:44
by thereheis
mine is all fiberglass,has a rolled lip which is glass also, no wood that i can tell..no wood trim nowhere.
Posted: Jan 19th, '07, 10:00
by craig mac
my hinges are thru bolted---as the heads are exposed on the deck--i had hatch sand painted to not make them as obvious
Posted: Jan 19th, '07, 11:02
Capt Pat is talking about the companionway hatch. Are you talking about the companionway or the deck hatch?
v-berth hatch
Posted: Jan 19th, '07, 11:31
by thereheis
the deck hatch
Posted: Jan 19th, '07, 12:14
Mis-interpreted your needs...
2 standard SS butt hinges with machine screws, cap nuts & lock washers.
