Epoxy, Varnish, or both??
Posted: Jul 14th, '06, 22:28
This off season, I did a lot of brightwork on my exterior teak. The process I used was to undercoat with West System epoxy and the finish with Epiphanes varnish. The process I followed (per Capt. Patrick's recommendation) was first coat of epoxy thinned 50% with denatured alcohol and then 2 more coats of unthinned epoxy. Then I applied 3 to 4 coats of varnish thinned 5% per Epiphane's recommendation. I am very pleased with the results.
My question comes up as to whether to follow the same proceedure for doing some interior teak as there should be little or no UV rays entering the cabin. I'm sure I could probably get away with using straight varnish, but the epoxy saves many applications of varnish to obtain the same appearence. Or, could I get away with just using the epoxy? Done right, I actually prefer the finish of the epoxy compared to the varnish, but I am worried that yellowing and fading may occur as in the exterior work, if not protected by the varnish. Any thoughts or suggestions?
