New raw water impellors for Sherwood pumps...
Posted: Dec 1st, '12, 14:25
On the Cummins 6B engines the original Sherwood raw water pumps had impellors that were a serious pain in the ass to remove.. there is limited room to work, and trying to pry them out of the pump casing and off the shafts with two screwdrivers or two needle nose pliers is damn near impossible, unless you own a dedicated impellor puller. I learned recently that Sherwood finally has a new design impellor in which rather than trying to pull the impellors out as above, you simply insert a 3/4" by 14 (threads per inch) bolt into the threaded outboard end of the impellor and as you screw it into the impellor it bottoms out on the end of the pump shaft, and as you keep turning it pulls the impellor off the shaft. I just installed these new impellors and just to see how easy it was I removed and replaced one of them. Easy peasey lemon squeezy!
