Relays vs. Soleniod Switches
Posted: Dec 28th, '06, 09:39
by Hyena Love
For wiring the underwater lights, I was planning to use Bosch type relays, rated for 30 amps, in order to avoid running big wire all the way to the flybridge and back down. I need the switches in the flybridge, in a semi-protected location.
Do I need to use solenoid type switches (like those used for remote battery switching) or are relays adequate? The solenoid style switch seems to be gross overkill. Lights should draw something less than 6 amps while in use.
Many thanks in advance.
Posted: Dec 28th, '06, 09:43
I think just relays is what you want. I use a seliniod for my bandit reel but it has a huge load at start, the lights do not ,as far as I know.
Posted: Dec 28th, '06, 09:48
Ernest: Just make sure they are rated for continuous duty at your amperage rating.
Posted: Dec 28th, '06, 11:30
by Hyena Love
Thanks for the confirmation.
