Hydraulic Steering Hose
Posted: Dec 15th, '06, 21:56
by Geaux Deep
Anyone have recommendations where to purchase hydraulic steering hoses with ends. I need to replace the hoses to my tower station. - RH
Posted: Dec 15th, '06, 22:09
Capt. Randle - places that make them up are a dime a dozen in any industrial area - most NAPA stores will make them up while you wait. I used to take an old one so they would get the fittings right the first time, and the brass fittings are the best vs. the steel ones for boat use since the pressures are not that much. On the other hand, I have installed a couple of SeaStar steering systems using the nylon tubing connected with the hardware store 3/8" compression fittings and that has lasted in one install 19 years and the other 12 with no issues. The pressure in the steering is pretty low.
Posted: Dec 15th, '06, 23:22
by Geaux Deep
Thanks UV - I'll get-er-done - RH
Posted: Dec 18th, '06, 16:12
by Garry
Randle,
I suggest replacing the hoses to the upper station with the teleflex black hose and fittings...same hose and fittings that service the lower teleflex helm to teleflex hydraulic ram. As I recall the tower helm is also teleflex. This stuff is cheap and easy to run and install. Good luck
Garry
