Rudders
Posted: Jan 25th, '12, 10:43
by mikepelham
I have just ordered oversized rudders from Capt. Pat. When I pulled the old rudders out, I noticed a collar with a shoulder that slides over the shaft and then the rudder goes through the rudder port. Ironically this was only on one of the rudders. My assumption is that there was play in the port and this collar was there to take up that space. Does anyone know where I could find one of these? Is a plastic/polycarbonate one ok or should I look for SS.
See link:
http://s1240.photobucket.com/albums/gg481/mikepelham01/
Posted: Jan 25th, '12, 11:46
Mike,
Does the addition of the collar bring the shaft diameter to 1 1/2"? If so, I can have the machinist add it SS...
As I mentioned on the phone, you may have two different sized rudder port.
Diameter
Posted: Jan 25th, '12, 14:39
by mikepelham
The outside diameter of the sleeve is about .03-.04 (30 thousandths) and that is worn, but its thin
Posted: Jan 25th, '12, 14:53
by mikepelham
Actually, the more I delve into this, I think its a function of the rudder port. Each of them have a step built into the rudder port to accept this bushing. Trying to dtermine who manufactured the rudder ports
Posted: Jan 25th, '12, 22:03
Mike
The original ports were round and impossible to find. When I repowered we called all over the country and not a one to be had. I needed to lengthen the collar section that the shaft of the rudder runs through. If you are beefing up the strut pads you might have the same issues. If you do you will need to find a good machine shop to help you out.
Posted: Jan 25th, '12, 23:40
Mike,
The collars can be made by most good machine shops, you want at least a 1/4" of material and at least 3 " long made out of Delryn.
Rudder ports
Posted: Jan 26th, '12, 05:32
by Marlin
Stuart propeller in Stuart Fl will fabricate rudder ports he has done a lot of them and shipped them around the states, Ed be the man, I was unhappy with the steering on my project after installing new rudders , he took a look and found the two rudders canting outboard instead of being perfectly vertical, he suggested we remov the bolts, rotate the rudder ports,( timed he called it) to get the vertical fix, red rill the holes, adjust the toe in again and the vessel performed much better, still not good at turning hard at cruise speeds, I have leaned to live with that, when I put the original rudder ports back in,I used the original hole pattern and the were no shims involved,FYI
Posted: Jan 26th, '12, 08:41
by martinciarpella
What are the size of the bigger rudders compared to the smaller ones?
