OIl Pressure/Electrical Issue
Posted: Aug 8th, '11, 08:49
Background: Yanmar 240's, Issue with port engine only, oil is full. Wiring on port engine is starting battery and house charged off the port alternator. Batteries connected via a Blue Seas ACR (automatic charging relay). Alternator output is to hot side of starting battery. Hot side of starting batttery runs to ACR, and then to hot side of house battery. Relay is to open only when there is a charging source for more than 2 minutes, and thereby charges up the house battery too. Alternator belt is basically new - less than 30 hours. Negative side of the house battery is NOT connected to negative side of the starting battery or to the engine ground (as originally configured, it changes below).
Instrument panel is powered off the starting battery. Batteries are Odysessy (under Dia Hard Label now).
Current Problem - When you accelerate, the oil pressure drops.
Oil Pressure readings - warm engine:
900 - idle - 30lb.
2400 - 18
2700 - 60
pull back to 2400 - 18 or less (sometimes down to 10)
pull back more to 2200 - 50lbs.
Over all gauge seems kinda bouncy.
SB engine:
900- 40
2400 - 60
2700 - 70
(It always has been about 10 higher than port).
History of problem - about a month ago, we were heading out. Oil pressure becgan to drop as I powered up leaving the marina. At the same time, the volt gauge began to drop. Rather than 13.8 to 14, it was falling down to 12. Checked the belt tension, checked oil, checked engine for other signs of problems, nothing.
So, determined it was an electrical problem, ran boat 50 nm., volt gauge continued to crash. Finally dropped down to 8. Turned engine off. Disconnected house battery, disconnected ACR. Both batteries on that side were pulled down to nothing. Used SB battery to re-start engine. Ran home at 2600. Volts were 14, oil pressure 50, and only the starting battery was used to run home. House was completely disconnected from alt. output.
Back at the dock, the house battery was put on a charger. It came up to 60% then kinda hung there. As if it would not take the charge. It was more than 5 years old, so I replaced it.
Starting battery was 60% charged by the alternator by the time we got back to the dock. It recharged fine.
Initial conclusion - bad house battery. Reconnected ACR and replaced house battery.
Ran this weekend again. All batteries 100% when I left the dock. Same story. Power up, volts drop, and oil pressure drops. Return to dock, disconnect ACR, and wire batteries in parrall (spelling). Meaning, hot to hot, negative to negative. Crank engine, volts now look right. But, I still have the weird oil pressure drop in this 2350 to 2550 range.
This weird oil pressure issue happens in the slip with no load, and under load.
Efforts to cure - pulled the dash panel, checked all connections, nothing appeared out of wack. CX applied.
Also checked ground conections at engine, battery connections, and made sure nothing had become disconnected. Oil pressure sender wiring looks good. Volt meter is accurate.
Current conclusion - subject to input from the board brain trust.
This is an electrical issue, not an oil pressure issue.
I plan to put a manual oil pressure gauge in the engine compartment, but nonetheless, why would the oil pressure drop at this relative narrow band of rpm's and then rise when the rmps are above or below the band? Does not make sense.
Could this be an alternator issue - voltage regulator? I did not swap alternators. And, the ground for the instrument panel is a common ground off the engine wiring harness. At the dash, this ground is jumped from gauge to gauge. Water temp gauge is not acting up. Tach on that side is not acting up either.
What sayeth the board?
Many thanks in advance.
900 - idle - 30lb.
2400 - 18
2700 - 60
SB engine:
900- 40
2400 - 60
2700 - 70
