Boat is in!! (and a potentially dumb question)
Posted: Apr 8th, '11, 16:51
by Wingnut
With fishing season just a few weeks away my B28 went in on Monday! (Chesapeake) See ya winter.....
Now for the dumb question....
I'd like to add a small- fully automatic bilge pump near my existing front pump but I want to mount it as low in the bilge as possible to help keep the boat a bit drier. Can I mount it directly to the hull with small stainless screws or am I asking for some sort of headache if I go that way?
Thanks all!
JD
Posted: Apr 8th, '11, 17:17
by Harry Woods
Use a wood wedge to level the pump in the bilge and glass it to the hull. Screw the pump to the wood not the hull.
Harry
Posted: Apr 8th, '11, 18:11
Usually those fully automatic ones have a detachable plastic base that allows you to remove the pump for cleaning or repair. If you have a dry spot you can probably 5100 it to the hull. Don't use 5200 or you'll have to chisel it off when you want (if ever) to remove it.
Posted: Apr 8th, '11, 19:28
by randall
or....you can get a little plastic mesh cage and glue that to the hull . no top necessary. keeps debris away from the pump, holds it in one place and makes it very easy to service and clean.
Posted: Apr 8th, '11, 19:43
Lots of pumps. You never know when you will need them. Ask me how I know. I have 5 pumps plus two chash pumps. 32,000. gals an hour with everything pumping.
Posted: Apr 8th, '11, 21:57
http://www.bertram31.com/newbb/viewtopi ... c8ccc51545
Check out this link. It will take you to an earlier discussion on this.
Posted: Apr 9th, '11, 07:11
by Wingnut
Thanks all, great ideas.
Now that the area of interest is WET any suggestions? (still kicking my self for not getting it done over the winter! )
I'm thinking a small piece of wood with some epoxy as a temporary for the season and then follow up with something like Tony / Cap Pat's suggestions in the link. Would the epoxy, PC7 or the like, harden under water?
JD
Posted: Apr 9th, '11, 07:50
5200 will harden under water, I believe.
Posted: Apr 9th, '11, 08:16
by randall
um......dry it? shop vac works well for this.
like brewster i am a big believer in pumps...4 (2, 2500 GPH) and very easy to to operate crash valves. trust me , that one time you open the hatch and see a rising foot of water in the bilge you will be glad you have them.
the theme for this month.............."dont ask me how i know!"
Posted: Apr 11th, '11, 09:37
by Wingnut
Randall,
Loud and clear! I'm going to use a manual pump to dry it as best I can and put in a temporary until I pull the boat next winter.
Now, let me tell you about my new freshwater system install yesterday! There places on that boat I never knew existed....
All I can say is after running the new lines I hurt in all sorts of strange places!
Thanks all for the input!
JD
Posted: Apr 11th, '11, 10:16
by Ironman
To get that last little bit of water out of the bilge.. put a Tee on the intake of the wash down line w/ a ballvalve.. .. make sure u have a screen inline near the pump./. your almost dry..
Wayne
Posted: Apr 11th, '11, 12:19
by Harry Woods
The forward bilge is dry when you are up on plane. Prefab the block and next time you have a run of an hour or so, while on plane, wipe the area dry, clean with acetone and epoxy the block in place. You should be good to go by the time you get back to the dock.
Harry
