Barbara Jean report # ?
Posted: Apr 8th, '11, 07:15
by Russ Pagels
Posted: Apr 8th, '11, 08:24
Looking good I haven't seen a finished boat with this layout. Seems to make a lot of sense when you glass in the front windows.
Posted: Apr 8th, '11, 14:42
So very cool!!!! I was on a boat in Bora Bora that had a layout similar, and Liz loved it. I agree about the head location. Pretty cool!
Posted: Apr 8th, '11, 14:59
Be very careful carrying fwd weight. There's a reason people don't do that to glassed in windshields.
Posted: Apr 8th, '11, 17:28
yep and it is critical on a 31 bertram i can even feel the differance when i try to hide that offshore anchor and chain in the chain locker. i think 50 lbs in the nose is worth 400lbs after the main bulkhead. the prop. shaft angle constantly pushes that bow down don`t put weight up there to help it along. they only make bow planes for subs not pleasure boat. ask capt .patrick about ruddering. make sure waste tank is in engine compartment yea its a bitch but essential!!
Posted: Apr 8th, '11, 20:47
Its not a high horsepower boat
Posted: Apr 9th, '11, 03:18
i believe it is a 330hp cummins powered boat. my post is in general to all this particular boat may be perfect .what i am saying is the lever effect that is 50lbs eight feet forward of balance becomes 400 lbs on the front part of the "see saw" hard to make up unless you have 3208 catapillar for power. fbc in a 2' to 3' sea wants to have waves cresting under front of side windows at cruise speed with the boat slightly bow proud .most effective when coming in a inlet riding the waves in .ruddering will cause dangerous condition of bow being push to one side or another.
Posted: Apr 9th, '11, 05:16
by Russ Pagels
Bob, 250 cummins.I am not a speed freak, I want to go fishing in comfort, and safety.most of the time you can run at only run 22 to 25 kts and be comfortable. Or as UV says rocking chair speed...Russ
Posted: Apr 9th, '11, 08:36
russ 22 to 25knt. is well within the scope of my discussion that is exactly the speed i was indicating. the fact is 99% of 30' boats that have a head locate the holding tank immediatly adjacent to the toilet. so we have a toilet , 20gallon holding tank, anchor@ rode,storage under v berth equating to about 8'from balance point. . 8 x 210 lbs (assuming a full holding tank at times) equals 1680lbs effect on the bow of the boat at cruise speed of 22knt not 90kns . the only way to nolify balance is to hard pipe from head to holding tank located to the stern of main bulkhead. this is not my 2 cents this is base on many hours of operation with 31 bertram.
Posted: Apr 9th, '11, 08:54
For the discussion of leverage yes the bow is affected by less weight than it takes to make the same change in the stern.
For the discussion of ruddering, this boat won't be fast enough to see that effect. The boat was sea trialed with this layout and has been running this way for years- like 15.
Running angle may be different than a balanced boat but it will be safe and dependable like the rest of our 31's.
Don't worry Russ the sky is not falling. If your worried keep one less fat guy in the V-Berth.
Posted: Apr 9th, '11, 09:20
there was no intention to alarm anybody just make them aware of raymond hunt design . i did not put the little white signs on the side of the gunnels " slings" that was the original desigh balance points of the factory. the point is altering it has limits one way or the other to maintain safety however at this stage of contruction no big deal to run a 11/2" pvc pipe to holding tank and flexible waste hose on each end and keep holding tank out of sleeping/eating quarters ---just sayin ! never seen a odorless holding tank.and at the same time increase fuel milage by decreaseing wet area.
Posted: Apr 11th, '11, 07:22
Bruce,
If you wanted to replicate this layout, and were concerned with weight (which I think is a worthy concern) what would you recommend? Foam core cabinetry with a veneer? Something along those lines?
Posted: Apr 11th, '11, 07:24
Let me clarify. Moving the head forward to the galley location. Not putting a head in the v-berth...
