Possible gear slippage / and changing engine angle
Posted: Jul 11th, '06, 13:36
as they say, its always somthin...
coming home from fishing the other day and noticed my port engine would rev up 200-300rpm momentarily, then immediately come back down to the normal cruise of 2300rpm. The engines are cat 3208Ts and the gears are ZF 225A (same as 220A except the down angle is 5degrees instead of 10).
This happened 7 or 8 times on the way home - each time was just a few seconds. When i got to the dock, i dove in and got a look at the props to make sure there was no obvious problem causing cavitation. I then pulled hte dipsticks on the tranny - looked OK, didn't smell burnt at all - but i drained it all anyway. there was a small amount of metal ont eh magnetic plug at the bottom of the pump but being that i'm probably the first guy in 14 years and 1400 hours to look at it, it was really a small amount. I also checked the screen/filter and it was completely clean.
I refilled and ran the boat again, and noticed the same thing happening. Seems like maybe the clutches are slipping - but it always stops after just a few seconds.
I spoke to ZF and they suggested i test the oil for metal, which i am doing now and should hear from the lab today. They also suggested testing the oil pressure to ensure the pump is OK (shold generate at least 300PSI according to ZF). Beyond that, there isn't much to do but pull the gear off and send it out.
Before i do that, i'm worndering if there are any other easy things to check. Could something else be slipping?. Is ther anything in the engine that could cause this?. If i really need to pull the gear, i'm wondering if its not a better idea to replace it with a new gear - pulling the gear in my boat would mean removing the entire engine - so going to all that expense makes me wonder if going with a new gear is a better idea.
...and finally - big geometry question here...if the new 220A gear is the same in all dimensions as the 225 except the down angle is 10 degrees - how far would i have to lower the front of my engine to make the alignment work - i have about 3 inches to play with - about 1.5" in adjusting the mount and another 1.5" could be gained my removing the aluminum shims in the mount itself. i'm estiating that the engine mounts are 47" forward of the shaft /tranmission coupling.
Thansk in advance for any ideas - ..nothing like big trouble in July:(
Joe
Joe
