Hydraulic steering and autopilot
Posted: Aug 29th, '10, 11:20
by FWHaas3
Yesterday in the canyon I lost hydraulic steering fluid from one of the hoses immediately to the rear of the junction with the autopilot. There are three hydraulic lines running to the rear of the boat beyond the auto pilot. As a result of the fluid loss, I lost control of the rudders at the wheel. However, the auto pilot still worked and I was able to run home using the autopilot, which is a four hour trip. Question: Are the hydraulics for the auto pilot separate from the hydraulics for the wheel. If so, that's a nice safety feature. If not, I don't understand how I was able to steer for four hours using the auto pilot, but had no pressure from the wheel. Any thoughts would be appreciated. At this point I am not sure which hose has the leak, since they are bundled and I have not begun the troubleshooting process. I am just trying to understand the system.
Fred Haas
Posted: Aug 29th, '10, 14:34
Part of the same system. Depending on where your check valve block is that could have prevented total failure. Its used to keep the auto pilot from rotating the wheel when operating.
Hydraulic fluid leak
Posted: Aug 29th, '10, 16:36
by FWHaas3
Update: The leak is in the auto pilot pump, not the hoses. The fluid is running from the pump down on to the hose bundle. The auto pilot is a B&G Network Pilot. It appears that the pump can be removed and replaced fairly easily. Questions: Can the pump be rebuilt? Is there an aftermarket pump available or must I use a B&G pump? Is a pump still available from B&G? Any thoughts to point me in the right direction would be appreciated before I start to spend money.
Fred Haas
Posted: Aug 29th, '10, 17:33
What kind of Pilot is it?
Posted: Aug 29th, '10, 18:10
The pumps aren't cheap. B&G?
Posted: Aug 29th, '10, 19:21
The new pump I put in this spring was 850$. The last one made it 16 years so I cant say anything.
Autopilot Pump leak
Posted: Aug 29th, '10, 20:36
by FWHaas3
The auto pilot is a B&G. I will let you know the price of the pump for
future reference. I have looked on the B&G web site. I just need to tie down the pump that goes with my system.
Fred Haas
Autopilot pumps
Posted: Aug 31st, '10, 11:26
by FWHaas3
Update: The B&G pump # is PMP-T1-12V. Retail is $900, wholesale is $675. It is out of stock. Available in four to six weeks from the UK.
A Simrad pump # RPU-80 is a suitable sub. Retail $825, wholesale $625. Available immediately. Only issue with using the Simrad pump is the threads for the plumbing, which can be overcome with an adapter.
B&G tech staff recommended the Simrad pump without hesitation.
Fred Haas
Re: Autopilot pumps
Posted: Aug 31st, '10, 12:07
by 34Hatt
FWHaas3 wrote:Update: The B&G pump # is PMP-T1-12V. Retail is $900, wholesale is $675. It is out of stock. Available in four to six weeks from the UK.
Fred Haas
When you install the new pump use Bruce's recommendation of putting valves in-between the hoses and pump. That way if you have a pump problem easy R&R.
I installed mine a few months prior and wish I had thought of it!
Auto Pilot pump
Posted: Aug 31st, '10, 13:09
by FWHaas3
Good suggestion! Until you hit me over the head with the suggestion, I was assuming the valves were already in the system. Maybe they are not. I will pursue when I remove the old pump.
Thanks for the thought.
fred haas
Auto pilot pump
Posted: Sep 20th, '10, 07:48
by FWHaas3
Update: Installed the Simrad pump this weekend. Actual pump installation is simple. Three hoses and two wires. Got the fittings to adapt my hoses to the Simrad pump from a local hydraulic shop.
If the pump runs in the wrong direction after connecting wires and hoses, just reverse the wires. Fortunately, mine ran in the right direction on the frirst try.
Bleeding the Hynautic system also worked as the directions said it would. the key is the bleeder valves on the bottom of the reservoir and lots of wheel turning.
Bleeding the autopilot lines also worked as the instructions said.
The system took a little over 1/2 gallon of hydraulic fluid, which I purchased on the internet from skygeek for about $40/gallon. West marine is $25/quart.
Simrad pump can be purchased for about $650 if you work at it.
If you have chatter in your wheel a good bleed job will remove the air in your system and eliminate the chatter.
Fred haas
