flybridge windshield fastenings
Posted: Jul 5th, '10, 18:57
by Bermuda Brother
Gentlemen,
Boat's in the water and I'm still just putting the finishing touches. I am trying to put the original flybridge windscreen back. I think I have the original metal fastenings for it that go through the holes along the windshield base which then anchor it to the flybridge proper. I have had these all re chromed too! I even have a new rubber gasket for the base too.
My problem is that I don't readily know how these little metal fastenings are usually attached to the plexi. The windshield had already been stripped off when I got the boat. It looks like the little "L" shaped fasteners would go all along the inside of the windhield. What I can't figure out is how these bits fasten to the base of the actual plexi windshield. ie what fitting goes on the outside of the windscreen?
What sort of fitting would go on the oustide face of the winscreen?
Sorry, its a tough question to formulate and I am struggling.
another question would be "how is captain Pat's old windscreen fitted to the flybrige?" are the fasteners still available? Is there an alternative method.
Hope somebody out there can offer an answer or photo.
Take care guys,
JJ
Posted: Jul 5th, '10, 20:46
by Capt.Frank
JJ,
I'll take some pic's tomorrow. I don't want to tell you wrong.
Frank
Posted: Jul 5th, '10, 22:16
After we see the picture, if they're not what you have, I may have some that I am pretty sure I have buried somewhere. If I remember correctly, my plexi was drilled and the narrow "U" shaped pieces at the ends of the threaded pins had matching holes for short small bolts and nuts to go through and sandwich the plexi to the "U". These were then hidden by the white rubber gasket that goes under and around the plexi. I think you have to punch holes in the gasket at the places where the pin goes through.
Posted: Jul 6th, '10, 10:59
As I recall, mine are eyebolts that bolt into the combing of the bridge. The windshield then bolts to them using an oval head machine screw and a finish washer from the outside through the eyebolt with an acorn nut on the inside. This info needs to be verified by someone else as i am going from memory.
Posted: Jul 6th, '10, 13:23
Mine is like Raleigh's. I have no idea if its original
Posted: Jul 6th, '10, 14:58
Mine is original.
Posted: Jul 6th, '10, 18:02
if i remmember corretly when i had my fbc, the bolts were a j hook with the open end facing down and nutted under the bridge, 2 holes
Posted: Jul 13th, '10, 20:27
by Capt.Frank
Sorry it has taken so long JJ. Mine are like Rawleigh stated A eye bolt trough bolted. Here is a pic.
Hope that helps
Frank
Posted: Jul 13th, '10, 20:35
Need them?
