restoring hull id numbers
Posted: Jun 28th, '10, 13:44
by spencer
Does anyone have experience restoring hull id numbers on the older bertram 31 hulls where the number is glassed in under the vberth area, I am rebuilding mine and would like to bring up the visability better and then coat it with a sealer , it appears better when water is applied and then dissapears almost when dry.
would like to keep it as is the only one that was found and is original
Posted: Jun 28th, '10, 15:52
by Mikey
Bet Capt Pat jumps in here, but I'd bet that the sealer would have the same effect as the water except permanent.
Posted: Jun 28th, '10, 17:20
Wipe it clean with denatured alcohol, let it dry and rattle can on a couple of coats of clear enamel, such as Krylon gloss clear...
Posted: Jun 28th, '10, 17:49
by spencer
Capt
Thanks for the reply
Spencer
Posted: Jul 1st, '10, 19:15
Capt Pat,
My only hull # I found was at the transom, a glassed over piece of paper, bad news all faded away..Id like to have another one reproduced any pics of a 66 vintage hull Id ? Thank you...BH
