Thinking outside the (Fish)box - Livewell Construction
Posted: May 23rd, '10, 13:34
by Vince Luciani
Capt. Patrick,
“Imitation is the sincerest form of flattery” or something like that. I wanted to build a livewell/fishbox and I borrowed most of your design concepts. However, I went about the construction with a whole different approach. Instead of making molds and foaming later, I started with a solid piece of foam and hollowed out to make the shape. It’s probably harder to describe than to show so I’ve included a bunch of pictures. I don’t have pictures of the very start where I combined seven (7) 24”x48”x2” pieces of insulating foam (from Home Depot) into one block of foam. I used spray adhesive to glue the foam together, no epoxy. I then shaped and scribed that block of foam to match the transom. After I was happy with the fit, size, etc. I glassed the outside of the block using all epoxy and three layers of 1708 biaxial. After the outside was glassed, I cut out the center section with a hot wire cutter. I used to be into RC airplanes when I was younger and used to make foam wings. I borrowed the technology. After adding the plumbing and the baffle slot, the inside was glassed. It’s been a lot of work, but I like the outcome. I can’t wait to mount it.
Block of foam shaped and fiberglassed
Molded Lid and Rim
Hot Wire Foam Cutter
After Cutting (Note inset routed piece of solid fiberglass for baffle)
Baffle
Water jets
Bottom section with drain
Fairing
One Coat of Primer
Posted: May 23rd, '10, 14:14
Thats alot of work. Very nice.
Posted: May 23rd, '10, 14:32
yes excelent work. one of these years when i shoot the top side iam going to have one off them
Posted: May 23rd, '10, 15:45
Good job, Vince. As Uncle Vic would say: "More'n one way to skin a cat, etc".
Reminds me a bit of when I one off'ed the livewell on Jerry Well's B31 back in '95.
Send me the plans for your hot wire cutter and we'll call it even.
Posted: May 23rd, '10, 15:51
by jspiezio
Cool result. That hot wire cutter is a neat toy.
Posted: May 23rd, '10, 18:25
by Ironman
That is one nice big tank.
like to see the installed pics
Wayne
Posted: May 23rd, '10, 18:29
How many pounds is it full of water? The whole thing.
Posted: May 23rd, '10, 18:48
Great job Vince....simple and sweet...who cares how long it takes...give each of us the same task and most of us would find different paths to the same place...gotta love this site...BH
Posted: May 23rd, '10, 19:33
by Vince Luciani
Thanks guys for the compliments. No problem Capt Patrick. I'll post some pictures of the hot wire cutter tomorrow. It's pretty simple. Search the RC model airplane sites and you'll find tons of info.
Brewster, the weight is as follows:
Inside dimensions = 45"x22"x10"= 9,900 cu. in.
9,900 cu.in. x 1 cu.ft./1728 cu. in. = 5.73 cu. ft.
62.4 lb/cu.ft x 5.73 cu. ft. = 357 lb
Not too bad. That's just a little more than some of my crew members! I'll definately post some pics after installed.
Posted: May 23rd, '10, 19:36
Pretty cool......Nice work
Thanks for sharing
Harry
Posted: May 23rd, '10, 19:37
Thanks.
Posted: May 24th, '10, 21:40
super nice work and my mind is turning because this job with a little twist can be used as under cockpit floor kill box and with the insulation ,the box will be so much better. please give us novice a little insigh on the wire cutting process.
Posted: Jun 1st, '10, 20:48
by Vince Luciani
I finally have some installation pictures for you. I could use one more coat of paint. The paint is Interlux Perfection Snow White brush applied with roll and tip method. I’m still trying to figure out my method of holding down the lid. I like the idea of having a removable lid. I might have to steal Capt Pat’s stainless pins and bolt design. You may have noticed that I offset the baffle so that it could be removed if I decide to mount the center lid more permanently.
Some of you had asked for some details on the hot wire foam cutter. I apologize for taking so long in getting back to you but I’ve been a little busy lately. The hot wire cutter is really pretty simple. You can see I made a simple frame with 1X3’s (I think). The wire is stainless wire that you get in any tackle shop. I use smaller diameters for the longer cuts and larger diameters for shorter cuts. You can see from some of the earlier pics I used 44lb test. The power supply that I used is a 12V power supply from Radio Shack. I had that around in my shop. I’ve heard that battery chargers can work as well as doorbell transformers with dimmer switches for power control. I’ve included a long link that has way more info than you are probably interested in. But, it does provide many designs for the cutter. The power is applied to the wire with alligator clips. I try to keep them as close together as possible to get the maximum heat when I'm making longer cuts. If you get them too close the wire will burn up. You have to play around with the gauge of the wire if your power supply is constant (like mine was). If you have a variable control power supply you can simple play around with the power settting. The bungee cord keeps the wire tight. When you apply the power to the wire it heats up and makes a nice clean cut. If you run the wire across a form you can cut any shape you want. When I cut the livewell, I made a top and bottom form from MDF and offset the top form from the bottom form to get the angle of the transom. (if you look at the second picture of my first thread you can see one of my forms laying on the ground under the livewell). I scribed the curvature of the transom onto the same MDF forms. I’m sorry I don’t have any pictures of that.
INSTALLATION PHOTOS
HOT WIRE FOAM CUTTER
HOT WIRE CUTTER LINK FROM MODEL AIRPLANE SITE
http://www.rcgroups.com/forums/showthread.php?t=628704
Thanks again for the compliments. All of you guys have inspired me with your projects. By the way, the deck is a work in progress as I have been installing fishboxes below deck this year. That’s for another post. I'd be happy to answer any questions on the hot wire cutter.
Vince
Posted: Jun 1st, '10, 21:02
Very nice work Vince, it came out very nice indeed. I have a power supply, but didn't realize that I had a wire cutter, thanks for info on the building the foam cutter.
Posted: Jun 1st, '10, 21:10
Use some wide velcro strips under the smaller central panel (both surfaces) and it will hold it down under the worst of conditions, yet you can remove the whole thing manually at the dock if you want to. Beautiful job. Walter
Posted: Jun 1st, '10, 21:18
That is pretty slick the way you did that. The paint job looks great also.
Posted: Jun 2nd, '10, 16:39
by Capt.Frank
If you used interlux paint. Is that what high build fairing compond you used?
You did AWSOME job.
Posted: Jun 2nd, '10, 17:14
by Vince Luciani
I used awlgrip 545 primer, no high build. I did the major smoothing with epoxy and microballons. I didn't have any compatibility problems between the awlgrip primer and the interlux perfection. I had done it before (awlgrip primer and interlux top paint) so I knew it would be OK. Hand sanding with a longboard is the key to getting a good paint job.
Walter, I love your velcro idea! That's just what I was looking for, something easy but will work. Thanks guys!
Vince
Posted: Jun 2nd, '10, 17:38
i like it, very nice
Posted: Jun 4th, '10, 16:15
by Jeremy
Very impressive!
post subject
Posted: Jun 4th, '10, 19:25
by Mike Moran
brain power at work great job
