prop and running gear anti fouling coatings
Posted: May 12th, '10, 09:22
by Mike Moran
Rawleigh I know you have used pettit system the question I have is pettit barnacle barrier as good to use ? price difference is great about 150.00 but if pettit kit lasts two years not so great thanks
Posted: May 12th, '10, 10:10
3 coats of Pam with butter. Let each coat dry for one day. Lasts all season and cost very little.
Posted: May 12th, '10, 10:18
by Craig Mac
what are you using this on? Props, shaft? My props usually come out clean at the end of the season , but usually have growth on my shaftes
Posted: May 12th, '10, 10:21
by Sean B
that might work well up there, but I think our Florida barnacles would eat your Pam with butter for lunch
Posted: May 12th, '10, 13:47
I learned it from some guys in Key West who leave their boats in yearround. It sounds stupid but it works great and cost little money. I also mix in a bottle of Pit Bull hot sause in my bottom paint and nothing grows on it. But if spending 150$ makes you feel better do it.
Posted: May 12th, '10, 15:00
Brewster Minton wrote:I learned it from some guys in Key West who leave their boats in yearround. It sounds stupid but it works great and cost little money. I also mix in a bottle of Pit Bull hot sause in my bottom paint and nothing grows on it. But if spending 150$ makes you feel better do it.
Could it just be you use your boat often....
Posted: May 12th, '10, 15:03
by Sean B
Ha! No spending money doesn't make me feel better, I'm not one of those. I've managed to procure two cans of the now unallowed but reportedly excellent "Tempo" clear antifouling coating, and intend to use that on the running gear during my next visit to the hard. Maybe I'll also try some coats of your your Pam on top of that. Can't hurt. The guys in the Keys certainly have the same growth problems that we do here
Posted: May 13th, '10, 09:58
I had good luck with the two part kit followed by Pettit Ultima Pro ablative paint.
The first primer coat was 6455 two part metal primer - $52.99/qt at West Marine
http://www.pettitpaint.com/fileshare/pr ... 645506.pdf
The second was Tiecoat primer 6627 - $39.99/qt at West
http://www.pettitpaint.com/fileshare/pr ... 662708.pdf
The third was the bottom paint.
The cheapest way to buy them is as the Underwater kit 6456
http://www.pettitpaint.com/fileshare/pr ... 645620.pdf
Start with clean sanded metal, then wipe with alcohol.
Posted: May 13th, '10, 11:38
by Raybo Marine NY
Sea Hawk sells a shaft and prop system
