max wax as a antifouling agent
Posted: May 4th, '10, 07:23
by Mike Moran
U Vic I would like to know how your max wax worked on underwater gear I had a lot of groth problems last year. thanks,
Posted: May 4th, '10, 07:54
Mike - apparently it works if the boat sits, but comes off with any movement. CX's original report that it worked came from one of their big customers, the Port of Auckland, NZ and was used on large slow-rotating props. A bunch of the Faithful tried it and it came off the running gear. I used it on a 15 h.p. Honda outboard prop and it came off. No dice is the short story.
Posted: May 4th, '10, 08:17
by Harry Woods
I used a new product by Pettit called Zinc Coat Barnacle Barrier this year to replace the Max Wax. Has anyone had results with this product?
Harry
Posted: May 4th, '10, 08:20
Harry- Is that stuff colored or clear?
Posted: May 4th, '10, 13:13
by Harry Woods
Walter,
The Pettit is gray. I wish we could get that old clear stuff that they outlawed about ten-years ago. That stuff was bullet proof to all growth. By the way, my Icom GPS shut down over the winter. I will make one attempt to give it a CX bath and then declare it dead. If that does not work, it is yours for parts.
Harry
Posted: May 4th, '10, 14:33
by chris pague
Harry yes I have used the Petit product and do not feel it did any better than bottom paint. At $24.00 per can and two coats still was not happy.
Went to nothing but bottom paint last spring and Digger has been in the water all winter. I have no barnicals on the trim tabs and the transom is clean.
Posted: May 4th, '10, 15:41
Harry-Or you can have mine for parts....Walter
Posted: May 9th, '10, 20:02
by Harry Woods
Walter,
A quick transfusion with CX has my GPS back from the dead. I spoke too soon.
Harry
Posted: May 9th, '10, 20:49
Another miracle!
