Sintra, Komacell, PVC panels and sunlight ?
Posted: Feb 23rd, '10, 16:34
I need to make a few panels for my cockpit. Specifically a non-structural bulkhead between the salon and the cockpit which is currently a half-canvas set up. I want to replace the tattered old canvas and faded half bulkhead with a full “hard†panel. Doing so will allow me to add a locking companionway door instead of the canvas one I have now and that way I can better secure the salon when I am not around.
I recall some discussion here long while back regarding Sintra and Komacell.
Sintra and Komacell are brand names for expanded PVC foam flat panels with smooth surfaces. They are generally used for making signs or other graphic displays. Generic brand sheet stock of the same stuff is also available from some suppliers.
I have noticed on the generic stuff it specifically says “Not UV stabilized.†And on the Sintra propaganda I have it says “suitable for outdoor signs for medium term use.†Only the Komacell claims to be suitable for all environments.
Has anyone else used this stuff in an outdoor environment? Does anyone know how UV effects them? Or how UV effects PVC in general? I don’t recall ever seeing any PVC drain pipe deteriorate in sunlight, for instance, but I don’t know if UV stabilizers are added to it or not.
The convenience of just cutting it to shape, screwing it in place and being done with the project makes this material seem appealing to me…. but not if I’m going to have to do it over again in a season or two.
Thanks, Peter
Thanks, Peter
