Posted: Feb 18th, '10, 19:33
i cannot give you cable lenght but difinitly run port and starboard as well as starboard throttle thru starboard pillar. port gear goes across top of fuel tank to port gear . this avoids a 180 degree turn of cable if you ran two down port and two down starboard pillars. port throttle goes down port pillar directly to engine cable bracket mounted on port side of engine.
Posted: Feb 18th, '10, 22:13
I have the exact same set up in a 75. I am trying to find my bill for the cables. If I can find it I will let you know. I will not be able to get to the boat for a couple of weeks in order to take a look. Plus the yard is fenced in and locked up for the winter. Plus with all the snow in south jersey I probably would not be able to get in the yard.
Give me a couple of days to hunt through all my receipts from my repower. I accumalated more receipts than you could imagine.
