Does any one know this boat
Posted: Feb 17th, '10, 13:27
by Russ Pagels
Hay, more questions,It seem that all the boats I'm finding are in NJ. So here I go again asking if any one has knowledge of The Fritz brothers in NJ. they were the ones who did the interior work on the boat.the boats name is Erica Michelle from Brielle NJ.thanks in advance....Russ
Posted: Feb 17th, '10, 13:38
by neil
pretty sure that jp knows the boat,it has been around here a while
Posted: Feb 17th, '10, 14:22
by Thums Up
Fitz bros do some really good work.......Don't know the boat though.
Posted: Feb 17th, '10, 15:11
You got a link to the listing Russ? Think it was redone a long time ago. It was done very well for its time. However if she's loosened up since the first refit it might be all for naught. Where is she at, when the snow melts I can have a look, maybe I can bring one of the guys that originally refit it.
Posted: Feb 17th, '10, 15:30
by neil
Posted: Feb 17th, '10, 15:49
by Russ Pagels
Thanks Neil you beat me to it. JP that would be great if you could do it.the owner ,Scott, is going to the boat tomorrow, and take a lot more pictures. He bought the boat from a bank. the engines are a mystery, he doesn't know the hours.from the pictures the cabin looks very good. not thrilled with teak decks but I can live with them.scott is a principle with Sliver Hawk boats, if any one knows him...again thanks for all the help...Russ
Posted: Feb 17th, '10, 19:41
you got to be kidding!!!!cummins engines installed, gears,pss seals, rudders,very very important teak covering boards,shafts, structs,thats 50,000 the rest of the boat including the boat itself is free!!!
Posted: Feb 17th, '10, 19:49
russ very conservative i would want $5000.00 to put that composite windshield /side windows would be another 2000.00 in tempered glass . just start adding up these extras.
Posted: Feb 17th, '10, 23:25
by Capt. DQ
Russ,
Those 250's are great running engines. Run all day on short money plus you have F/W cooled aftercoolers.
DQ
Posted: Feb 18th, '10, 10:11
If the irons good in that one the rest looks pretty easy to fix. Worse case would be the deck is soft. But for the 50K you could add a Cabrera deck and box system to the boat and still be ahead of the curve.
Generator looks a little damp.
She was winterized right?
I'd make an appointment to look at this one. The pics look pretty good. I'm jammed out for the next few days but will try and get over to see her when I can.
Posted: Feb 18th, '10, 12:07
Looked at it.
call me 717-891-1054
Posted: Feb 18th, '10, 13:16
JP Dalik wrote:Looked at it.
AND ?
Posted: Feb 18th, '10, 13:27
by dougl33
I'm thinking maybe its a train wreck?
Posted: Feb 18th, '10, 13:31
by Russ Pagels
I just want to thank every one for all there help. JP thank you very much for all your help looking the boat over.a deposit is going out,and dependent on survey of engines, boat and sea trial. If the boat checks out the boat wiil have a new home.any one want a '73 gaser in great shape. when the deal is done I'll post it with Capt. Pat..thanks again to Pat for this great site . you meet the nicest people here!
Posted: Feb 18th, '10, 13:56
by dougl33
Well that's good news. Good luck.
Posted: Feb 18th, '10, 14:12
AND ?
Russ congrats on pulling the trigger on the deposit, to the rest of the team here's what I spoke to Russ about on the phone. When she was redone it looks like she was completely re gelcoated. All of the bulkheads forward had been re-enforced and glassed in or just replaced all of the bulkhead to hull attachments were solid. All the modifications to the original layout are holding up very well. The forward head lays out well for those that may of though otherwise. There is more tackle storage in this boat than many I have looked at. Looks like a Roger Fritz interior redo but without talking to him I can't be sure. Whomever owned the boat after the original refit seems to of cared about it. No nasty birds nests of wires everything is clean. The 582 and 951X along with the VHF were on the boat and covered. There is a Robertson autopilot, the main steering lines are still the original copper except for where the autopilot pump was tee'd in, The vessel still had the original Bertram breaker box down below with an updated sub panel overhead in the accessible headliner. The wiring appeared redone and the breakers functional
The only visible chink in the armor is the deck, the supports underneath appear in good shape from what I could see. It is not soft "feeling" however the teak is very thin and lifting in a few places. The engine beds and bulkheads look to be in good order with a little rust on the outboard side as to be expected. The gen set is a one lung belt driven, phasor type unit. Guessing its a 3600rpm screamer. I was told it runs I'd probably pull it and refresh it after attending to the deck. the engines and transmissions were well taken care of with no visible oil leaks, the boat has shaft seals and there were no signs of water spraying around the bilge. Both gears showed only normal signs of age and both shifters worked smoothly. The exhausts are glassed in 5in for a custom look, the boat does have a composite rail and it is fit nicely to the vessel. The window frames are still aluminum with plexiglass or lexan one piece inserts.
The boat was sitting with a pair of 20x23 4 blade hytorques with a light cup. I can't say I remember seeing trim tabs. The bottom could be stripped and barrier coated, it has the updated lifting strake layout and no hull number in the transom corner.
The boat presents well. The owners original plan was to take it and re do it similar to "that pretty blue bertram at Carvers" but things changed with his plans. I explained to him that "the pretty blue bertram" was mine. Small world he loves what we did with our Bertram and I love the 24 Silverhawk he builds. As a boat builder he has access to fabrication materials most of us can only dream of. I'd be tempted to work with him in fabricating a replacement deck for this boat.
Best of luck with this boat, from everything I saw if the engines test out you'll have a great boat to do anything you want.
Posted: Feb 18th, '10, 19:38
excellent survey do you do this for a living? ha, ha for russ this is like having a long loss brother.
Posted: Feb 18th, '10, 19:47
by ed c.
Russ, good luck, it looks like a keeper. The interior looked great.
