upper helm ignition on/off circuit
Posted: Sep 28th, '09, 14:37
by Rocky
Hi guys, just thought I'd say Hi and to ask, what typically shuts off the engines from the upper helm, the coil power circuit(gas) or the entire dash supply from lower helm? I know there is a "Bertram" circuit diagram out there somewere but I do not have one. There is a provision for two switches under steering wheel above the little doors, I'm assuming that is where they were. I would imagine you would want to be able to shut them down from up there, esp. in an emergency!
Thanks Rocky.
Posted: Sep 28th, '09, 14:42
by Skipper Dick
Mine is the main power switch for each engine bank, and they are separate from each other.
Posted: Sep 28th, '09, 15:22
by Rocky
Thanks Dick, that sounds like what I had in mind. Are those switches switching P and S at the lower helm off as well? In other words , breaking the circuit before the lower helm's P and S dash power?
Rocky
Posted: Sep 28th, '09, 17:20
Rocky
On the 31 with Gas engines, there are two ignition switches on the bulkhead under the wheel. The start buttons are part of the instrument panel.
There are tow main breakers in the Cabin on the FBC. These serve to kill the power to the engines and the switches.
Posted: Sep 29th, '09, 06:48
by Skipper Dick
Rocky,
I do not have a lower helm, but I do have three separate battery switches. There are separate banks for the port, starboard and house and they are maintained separately by an isolator. The switches that control the power for the engines are located on a panel beneath the hatch that is beweeen the engines. I have it set up so each battery switch will operate from either battery bank or both, just in case one bank craps out on me.
I do not have a switch to tap into the house battery incase they both crap out, but I can change the lead to the engine switches in a matter of a few minutes in case that unlikely scenario happens.
This is sometime a pain in the ass. My fuel gauge is located on the starboard instrument panel and only works if I have the starboard switch on. I have my fuel monitoring system tied into the port panel and have to switch the port battery switch to on just to monitor the starboard engine. I'll solve these little irritations later this winter when it isn't so hot to work on the boat.
Dick
Posted: Sep 29th, '09, 06:52
Most of the 31's I've worked on with dual helms, you had to have the lower ignition switches on to start and run.
Its no big deal to change that though to have two independant ignition circuits.
Posted: Sep 29th, '09, 07:09
Rocky; I have a 1966 wiring diagram if it will help you. Send me your email if you want it.
Posted: Sep 29th, '09, 14:46
by Rocky
Thanks Bruce, I think I will run my switches as an interupter Before the lower helm supplied power so it kills everything from up top, (P and S being seperate switches of course).
Rawleigh, yes I would greatly appreciate that diagram! Even if I don't keep OEM, it is nice to know how it was done.
gareism@aol.com
Thanks again, Rocky
P.S., We've decided to keep our B31, Thank God!!
