cabin and v-berth ceiling
Posted: Jun 24th, '09, 21:52
i an trying to move forward on the finishing of the interior in particular the ceiling. the new boats like cabo have a " metal t-track" when you install leatherette you tuck the material into the track with a stiff putty knife . the ceiling has no screws or buttons showing just straight line where the material tucks in. rolls are 3' wide so this tee track is put 3' on center . i cannot for the life of me find this trak anywhere don`t even know the proper name but it is oem on luhrs 41' .-help
Posted: Jun 24th, '09, 22:46
by Buju
Bob, with your connections at work... Can't you simply contact Luhrs and ask them if they'd provide the contact info for the vendor/manuf?
Posted: Jun 24th, '09, 23:12
by JK
If you can't find out who makes it google Jersey Cape yachts and shoot Genine or Wayne an email and they will let you know. I watched them install exactly what you are describing and it does look great. They had a plastic track and used a staple gun to tack the track to the wood then rolled, stretched and put in the fabric with a putty knife, or what looked like a pizza cutter.
--JK
Posted: Jun 25th, '09, 07:23
by alano
bob, take a look at the bottom of this page, let me know if this what you're talking about as I'm doing the v-berth on my 35. Br, Alan.
http://www.barbourcorp.com/marine-awningtrack.htm
Posted: Jun 25th, '09, 08:17
gentlemen thanks for the quick answer i should have not thrown you off course with the metal t -track because it is not matel it is in fact plastic,but the color of metal . installed with a pizza cutter thats it and can be removed to get out wiring and then reinstalled.buju anytime you contact a dealer to acquire a product that they buy you run into a time factored. the top of the line boats like everglade`s has the best seats and cushions i have ever seen and it just so happens they are made on long island . they driver seat is a power seat with the logo embossed on it with a keyed console compartment between seats. i attempted to put this on the bridge of my 31 but they make it special for everglades and the set up was 4" to wide (plus the logo) had i known the manafacturer at the time i would have went there all and all it is best not to go thru a third party.
Posted: Jun 25th, '09, 21:43
Bob
Don't forget to post Pics. Would love to see how it works out for you.
Posted: Jun 26th, '09, 04:44
by Buju
I hear ya Bob. But what i meant was not to contact the dealer, but the manufacterer (Luhrs or Jersey Cape like JK said), and ask for the extension
straight to the guy in charge of materials purchasing. Might have to do a little legwork, but it shouldn't take too long before you've got your answer. I've done similar things successfully...usually get transfered 3 or 4 times, and you've got your answer.
Looks like Alan has got it for you though...Barbour corp.
Posted: Jun 27th, '09, 21:25
On the topic of interior ceilings, I am considering standard cabinet grade material. I wanted to do a mahogany panel on the ceiling. If I saturated the back side with epoxy resin and varnished the face, would it hold up to the moisture?....or would it require a "marine grade"?
