454 exhaust manifolds and risers
Posted: Mar 27th, '09, 12:27
by JohnV8r
It's that time again. I need to replace my 454 exhaust manifolds and risers. Can anyone give me a recommendation where I should be purchasing these? My 454's are freshwater cooled. Also, I see two styles; center and slightly off center. Any advantage to either?
Thanks in advance.
JohnV8r
Posted: Mar 27th, '09, 14:33
by Skipper Dick
JohnV8r
I googled for a couple of days and found the best price for manifolds and risers at the url below for my Merc 350's.
http://bpi.ebasicpower.com/mm5/merchant ... BasicPower
Posted: Mar 27th, '09, 14:52
John-
I have the old log style. I remember that someone posted at sometime (narrows it down, huh), that they had gotten an aftermarket center-riser manifold and when bolted up it didn't clear the engine box. So, make sure whatever you get, you have adequate clearance. Apparently they're not all the same.
John F.
Posted: Mar 27th, '09, 20:26
I believe that post was within the last two months.
Posted: Mar 27th, '09, 22:17
by Ironman
:When I had the gassers ...(Mercruisers) I used OSSCOs?Purchased in L.A. somewhere..
Usually the manifolds last far longer than the elbows..
Wayne... P.S. got a 53#er last time out.. LOCAL
