Props
Posted: Nov 10th, '08, 08:18
by Bill Mckinnon
Hey guys am going to repower with the 315 yanmars, can anyone tell me what would be the best prop configuration I should be looking at? I had gas engines before and have 18X19's on there now any help would be great
Capt. Bill Mckinnon
Posted: Nov 10th, '08, 09:58
Bill,
Presuming you are going with 2:1 transmissions, start at 20x24 for four blade, 21x23 for 3 blade. Tweak from there to find your correct loaded RPM, which should be no less than 3900 for the 6LP. Both ways will probably need a medium cup.
Posted: Nov 11th, '08, 07:11
Pats got it spot on. Don't forget 1.5" a22 shafts.
Posted: Nov 11th, '08, 20:33
by charlie falkenstein
bill.........i asked the same question 2 years ago,went with the 315 yanmars capt pat told me to go with the 2:1 TRANS,1.5 dia. shafts,4 blade 20 by 24 nibral props and i must tell you it is one SWEET PACKAGE!
3200 rpm gives me a solid 27/28 knot cruise wot 3900 rpm i got up to 34 knots(dry) and the boat is unbelievable out of the hole. i also put in a MASE gen set. boat burns 1 gallon for every 1.5 miles. i live in new jersey and run the canyons alot and i just love the performance.
GOOD LUCK!
