Light socket
Posted: Oct 7th, '08, 22:09
by Goodgrief
Any body know the part number for the Perko light socket in the bow chalk nav. lights. One more thing, I have rebuilt my engines and Trans carbs alt all the stuff, the port engine is burning 17 gph stbd 10. I swaped carbs port to stbd, checked timing idle and advanced, shafts are not bound. What else could it be?
Posted: Oct 7th, '08, 23:28
Are there any differences in the heads, cam or pistons from one engine to another???? Are you sure that the cam timing is correct????
Harry
Posted: Oct 7th, '08, 23:56
Goodgreif,
I couldn't find exact replacement sockets for the bow chock/lights, I went to the local NAPA store and got nearest size spring loaded sockets with pig tail wires, I had to grind the flanges down a little to fit into the hole. I bedded them in with clear silicon, they have be in the boat for 10 years and are still working fine. Used single filament back-up tail light bulbs. Cost about $ 8.00 back then. Can't help with the carb issues I've got throttle body fuel injectors on my 454's.
Posted: Oct 8th, '08, 09:38
If you have counter rotating engines, the firing sequence and your timing mark would be different on your starboard engine. For whatever that's worth. Walter
