Foul weather gear
Posted: Aug 19th, '08, 21:38
I have West Marine rain jacket that appears to be in great condition. It is about 7 years old and not a heck of a lot of use. I found out during Fay that it is now for some reason as water repellent as a cotton T-shirt. I was wondering if anyone has tried ScotchGaurd on one of these jackets. I think it was just under 200 dollars when I bought it and hope it can be saved. Any suggestions?
....................No, I will not spray is with CX!
Posted: Aug 20th, '08, 07:06
ScotchGaurd will fix it. Wash it first with Tide. And if that does not do it CX!
Posted: Aug 20th, '08, 08:10
If the jacket is Gore tex, there is a spray on product that will rejuvinate the waterproof nature of gore tex.
If not, I am sure that Brewster is correct.
If that fails to live up to your satisfaction it can absolutely be waterproofed by wearing a set of Grundens over it. The overalls and jacket by Grundens will keep a hurricane out, especially if you have your back to it...
Posted: Aug 20th, '08, 12:14
Thanks guys. Tide sounds easy enough to me. The jacket is 100% nylon with a polyeurethane coating, which I am guessing is the white coating on the inside. That part is cracked and peeling in some spots. I will give it a whirl though.
Posted: Aug 20th, '08, 13:15
Dug...
If you havce been watching "The Deadliest Catch" show on TV, a lot of the guys wear Grundens gear!
Posted: Aug 20th, '08, 15:52
Grundens or Viking for commercial wear. Helly Hanson is OK too.
I too have a jacket that the plastic has peeled and cracked on the inside. I was wondering why I got so wet in the last tropical storm and that was the problem. I think that the heat of being left on the boat or in a car makes them deteriorate over time. I may try Scotchguard. I don't have much to loose!
Posted: Aug 21st, '08, 07:25
If its cracked its done and should go in the trash.
Posted: Aug 21st, '08, 09:40
I kind of figured that Brewster. I bought a new one at the boat show, but was hoping to use it as a work jacket.
