Looking for a sander...
Posted: Jun 12th, '08, 12:02
I've been looking for a 6" corded or pneumatic sander with a 90º configuration, single action. Damned things just don't seem to exist... I've been looking off & on for years.
Plenty of dual action units, but I need single action. Makita makes one that's semi-90º via the body & handle configuration, but the balance is terrible. Had one of those once, and thankfully it got stolen.
A 4 1/2" angle grinder, fitted with a 6" pad, would be great except for the 11,000 rpm aspect. Foam sanding PSA pads are only capable of handling a maximum 7,000 rpm. I may have to try an electronic speed control, but would prefer not to.
Anybody know of a low center of gravity 5,000 - 7,000 rpm single action sander that's available? Variable or fixed rpm makes little difference...
Posted: Jun 12th, '08, 12:11
Hey Pat
I am looking for a sander also.......I'm looking for one that will show up in the mornings for work.........
Here at the shop I walk out on the floor and yell "I need a welder" ! ! !
Rod yells back "er" or "or" then he tells me that there are 4 of them in the corner.....just help your self
Ha Ha
Harry
Posted: Jun 12th, '08, 12:23
by clay
Not sure if this is a fit but I have been using one for a year with wet discs to eliminate the dreaded fiberglass itch. 4500 max rpm but can jump it up with more than 90psi. Works dry as well, I bought the 99.00 one to see how it went and it just keeps on going. I use a 6" thread on pad when using sanding disc.
http://cgi.ebay.com/3-5-Air-Pneumatic-W ... dZViewItem
Clay
Posted: Jun 12th, '08, 12:50
Clay, thanks! Closer to what I'm looking for sure... I do prefer electric over air for constant duty tools, but this might be my only solution.
Harry, know the feeling. I only have myself & I to yell to and those two guys aren't worth a damn. Gonna' fire both of 'em someday. But then I'll only have the dogs to talk to...
Posted: Jun 12th, '08, 13:56
by Raybo Marine NY
capt pat- milwaukee angle grinders have speed adjustment- might be a good choice as they last forever
Posted: Jun 12th, '08, 14:52
These are 7", but should be able to be converted as they use standard 5/8 x 11 spindles:
http://www.northerntool.com/webapp/wcs/ ... _200026774
They also have a cheaper version:
http://www.northerntool.com/webapp/wcs/ ... _8420_8420
Posted: Jun 12th, '08, 19:31
by Ironman
Hey Pat: have you tryed one of these.
Fein tool?
.Made in Germany.. They do just about any hard to reach (sand ,cut or scrape) amazing.
Wayne.
Posted: Jun 13th, '08, 10:45
by DRIFTER31
Capt Pat....
www.smartshoppersinc.com This is an autobody mailorder supplier who i buy from and the they make 2 direct air driven DA's one is 8" National Detroit model900 and one is 6" National Detroit model9600 179.00 and 169.00 I have the 8" model and use it strictly for cutting large areas and she kicks ass. They both come with the sticky-back pad.
Troy 31Tiara"DRIFTER" Lafitte La
Posted: Jun 15th, '08, 13:51
by Marshall Mahoney
http://abrasives4sale.com/pads_for_h&l_discs.htm
I used 4" and 6" hook and loop backing pad on my side grinder from these guys. Worked good (and fast) for fist pass sanding, but throws a lot of dust. Cheap too. A lower speed tool may be better.
--Marshall
