todays work
Posted: Apr 29th, '08, 18:27
by 1962 31
tank out epoxy coated engine mounts removed bulk head made template for new one and had a blast grinding old fiberglass and got out that fire tank
[/img]Image
[/img]Image
[/img]Image
Posted: Apr 29th, '08, 18:49
Tom,
You're making good progress! The rough in/out is always the most rapid & somewhat rewarding part of a project boat. It's when you get to detail stuff that things slow down, sometimes to a crawl, & you begin to question your sanity... But it should all be worth it in the end when the dock pelicans are OOOHing and AHHHHing over your newly re-finished classic.
Posted: Apr 29th, '08, 18:56
Don't sugar coat it Pat.
By the time your done you'll have wanted to stick your head in a running lawnmower a half dozen times.
Posted: Apr 29th, '08, 19:20
Hey, Bro, I've been thinkin' of getting a crew cut myself lately...
Posted: Apr 29th, '08, 21:10
Tom
Before you cut that Bulkhead, decide if you are going to go with a bigger fuel tank. If you are you will probably need to raise the hight of the deck and the bulhead also.
I used Coosa Board on mine. Not cheap but I think well worth it.
I will be around late Saturday and hopefully Sunday weather providing if you want to take a look.
Also get those strut and rudder pads replaced. Don't skip those, you are too far into it to let it go.
Posted: Apr 29th, '08, 21:56
Tom........your going like gangbusters........keep up the good work and thanks for keeping us posted.
Harry
Posted: Apr 30th, '08, 07:08
by 1962 31
tony
i definitely want to stop by and check out a few things
I'm trying to get at least a rough template for the deck done first before i start ripping into any thing else that way its one thing at a time
and guys thanks for the enthusiasm it's keeping me moving forward
Posted: Apr 30th, '08, 07:13
by jspiezio
A 1962 31' Bertram. Older than I am and it still looks better.
Posted: Apr 30th, '08, 19:17
Tom
I will call you Friday afternoon after I find out if I have to pick up my struts or not. If they are not ready then I will be there earlier on Saturday and of course Sunday weather permitting. If my struts aren't ready my Cummins guy is not going to be happy. He called me today and wants to move the boat over to his shop to get ready for the install. I need the struts to lign up the shafts.
Talk with you on Friday.
Posted: May 1st, '08, 16:34
by 1962 31
got a rough deck template in today
[/img]Image
Posted: May 1st, '08, 21:27
Tom
You are really moving. Make sure you don't overlook anything in the rush.
Posted: May 2nd, '08, 07:30
Its really coming along.
