Riser Gasket Gas
Posted: Apr 16th, '08, 07:24
Folks,
Closed / Freshwater cooled Merc 454's w/ center risers
I've change risers several times but can't recall ever knowing a marine mechanics tried true and best practice for gasket installation.
First:
Sealant, Use it or not? RTV? The gaskets I bought are OEM Merc or quicksilver and have a heavy silver coating that I believe is meant to be used without sealant. Didn't notice if there were instructions yet.
Second:
Block off plates, I bought SS block off plates. Then noticed that I had not installed them previously. Maybe the block off OEM gaskets said I didn't need to use them. Are SS block off plates necessary, or is there a special gasket that does the block off job with one piece.
Regards,
Mike Dolan
www.lightningshack.com
First:
Second:
Regards,
Mike Dolan
