01 F250 4X4?
Posted: Feb 3rd, '08, 19:32
by thuddddddd
Any one know what the front and rear diffs are in this truck? or wher I can find the info..
Posted: Feb 3rd, '08, 19:46
What, What
Thought the rears were corporate Ford and the fronts were built by Dana.
What ratio? My 04 is 3.73 think that's a standard gear with the 6.0.
You should be able to find axle ratio in your owners manual. It's referenced off your VIN# axle code C1 is how mine reads.
Posted: Feb 3rd, '08, 19:50
by thuddddddd
more intrestd in if they are dana 50's, 60's yada yada . Ended up with a cable locker that belongs on a dana 60
Posted: Feb 3rd, '08, 19:52
by thuddddddd
"it appears to me that both the f250 and f350 in your year truck are Dana 50s and Sterlings in the rear. And there is a difference between front and rear Dana 60s as the front is a reverse rotation diff. "
Posted: Feb 3rd, '08, 20:02
I can't believe you've got a 60 front end in a 250. Looks like you got more parts to put in that warm empty building.
Posted: Feb 3rd, '08, 20:15
by thuddddddd
Yea, well if I have a 60 in the back, thats where the locker is going
Posted: Feb 3rd, '08, 22:34
by Kingfish
There should be a tag on both the front diff. and the rear diff, if no one has thrown them away.
If you can come up with those #'s ,I should be able to tell you what you have. Vin# wouldn't hurt either, all 17 digits.
I work in a Ford parts dept.
Posted: Feb 4th, '08, 10:24
by thuddddddd
Jim the tags are long gone, after 300+k on the beast
the vin is 1FTNW21F01EB29721
Any help would be great
Tim
Posted: Feb 4th, '08, 23:01
by Kingfish
Tim
I'll check tomorrow and see what I come up with.
Posted: Feb 4th, '08, 23:12
by Kingfish
This is what I could find from home, more research tomorrow when I get to work.
Vehicle Highlights for 1FTNX21F21EB27921
Vehicle Description: F250 SUPER CAB PICK-UP 4X4
Model Year: 2001 Vehicle Model/Type: X21
Production Date: 15-NOV-2000 Exterior Paint Code: Z1
Tu-Tone Paint Code: Interior Trim Code: 9H
Gross Vehicle Weight: 08800 Wheel Base: 158
Components for 1FTNX21F21EB27921
AXLE
AXLE FRONT FWD 1:
AXLE FRONT FWD 2:
AXLE FRONT RWD 1: D271D
AXLE FRONT RWD 2:
AXLE REAR FWD 1:
AXLE REAR FWD 2:
AXLE REAR RWD: 409H
INSTRUMENT
INSTRUMENT CLUSTER 1: XC3F10849CE
INSTRUMENT CLUSTER 2:
INSTRUMENT CLUSTER 3:
CHARGING
ALTERNATOR ID: F81U10300EB
STEERING
STEERING ASSEMBLY: XL3C3C529AA
STEERING PITMAN: YC353590AB
STEERING SHAFT:
COOLING
COOL RADIATOR ID: YC3H8005BA
COOL HOSE UP ID: YC358B274CC
COOL HOSE LOW ID: YC358B273CF
SUSPENSION
SUSPENSION SPRING CODE:
SUSPENSION SPRING ID FRONT: YC355310AMC
SUSPENSION SPRING ID REAR: YC355560CA
SUSPENSION AUXILLARY REAR:
DSO
SPEC DIST CD: 48
TRANSMISSION
TRANSMISSION ID: 1C3P7000FA
EMMISSION
EMMISSION CALIBRATION: 1F719S0A
EMMISSION PROC ID: 1C3F12A650ZC
WHEEL
WHEEL COVER ID 1: 1C341A108AB
WHEEL COVER ID 2:
WHEEL COVER ID 3:
WHEEL COVER SPARE: F81A1015AA
WHEEL COVER ROAD: F81A1007MA
ENGINE
ENGINE TAG ID: BE002AA
DRIVE LINE
DRIVING SHAFT REAR ID: F81A4K145LTC
DRIVING SHAFT FRONT ID: YC3W4A376MA
DRIVING SHAFT COUPLING:
BUMPER
FRONT BUMPER: 1C3417750GFYBCC
REAR BUMPER: YC3517775DBSMAW
GRILLE
GRILLE 1: 1C348200BAYBAC
GRILLE 2:
GRILLE 3:
TRAN CASE
TRAN CASE ID: F81A7A195JD
MIRROR
MIRROR 1: YC3517683FAYGAK
MIRROR 2: YC3517682FAYGAK
FUEL
FUEL TANK 1: 1C349K007MA
FUEL TANK 2:
FUEL SEND MID ID 1:
FUEL SEND MID ID 2:
FUEL SEND MID ID 3:
WIRING
WIRING ENTITY 1: 1C3T14401PAA
WIRING ENTITY 2: YC3T14405APD
WIRING ENTITY 3: 1C3T15525BB
WIRING ENTITY 4: 1C3T12A581FAE
WIRING ENTITY 5: PM1C3T13A409AC
WIRING ENTITY 6: YC3T13A576CA
WIRING ENTITY 7: 1C3T14A005LAC
WIRING ENTITY 8:
WIRING ENTITY 9:
WIRING ENTITY 10:
WIRING ENTITY 11:
WIRING ENTITY 12:
Posted: Feb 5th, '08, 00:35
Look here...
![Image](http://77cj.littlekeylime.com/img/Danadiag/BOM.GIF)
Posted: Feb 5th, '08, 08:43
Now this kind of information is why I love this site.
You guys are amazing!
Posted: Feb 5th, '08, 21:22
by Kingfish
Well Timmy,
Sterling rear diff. 3.73 gear - limited slip - 10 1/4" ring gear.
Front diff. from what I can find is a Dana 50 (from 2 of our techs), our parts listing doesn't specify the make just lists the parts by part #.
I'll be glad to dig further if you want, let me know.
Posted: Feb 5th, '08, 22:09
TIMMY GOT SOME PARTS FOR SALE!!!!!!!!!!!!!!!
If you get a winch your garuanteed to never get stuck.
Had an F150 with 33's and open diffs, was a little worried it might not have enough ooomph for skipin across the corn fields to goose hunt. Got a winch, never got stuck- its the old story, if you have it you never need it.
Posted: Feb 6th, '08, 07:17
by thuddddddd
thanks kingfish, but it seems what I have for parts won't work. so I'll be selling it to JP and getting a winch, to go alon with my wench
Posted: Feb 6th, '08, 07:32
Just send your check big fella, we'll talk lockers later
Posted: Feb 6th, '08, 07:42
by thuddddddd
packing it up right now.
They plan on moving the tubb around 11:00 today, so make sure you bring your work clothes on your next visit
Posted: Feb 6th, '08, 07:51
by offshore31
it's about time. let me know where it is.
i can't make it down this sat. other than that, let me know when you guys will be there and i'll help torch, i mean work on it.
Posted: Feb 6th, '08, 08:08
by thuddddddd
speakin of 4x4 parts trucks, wheres yours? I need some low mileage stuff
Posted: Feb 6th, '08, 08:42
is sea tow moving it for the new reef program ????
Posted: Feb 6th, '08, 09:13
Timmy gotta come through your neck of the woods Monday night on my way to Vt. maybe I'll stay in Amesbury and we can get a couple drinks and you can show me the Tubbs final resting place.
