Radius on helm pod Roundovers
Posted: Jan 4th, '08, 21:19
by muddywater
Hey guys,
I was just wondering what radius (or diameter) is typically used on the helm pod round-overs.
Thanks!!!!
Posted: Jan 4th, '08, 21:22
i used a 11/2" round over bit and was vert satified with results.
router
Posted: Jan 4th, '08, 21:59
by muddywater
So you just used a router rather than a hand plane & sander and you felt like the radius on your round-overs was sufficient? Hmm... that definitely sounds easier than trying to make all my plane lines straight. Tempting...
Posted: Jan 5th, '08, 15:47
i don`t know if i posted this in the past ,if i did bare with me.i hand picked a 2"thick piece of beautiful grained burmese teak.look all over the northeast for a bandsaw with a 30" throat ,low and behold there was a old sawmill on eastern long island.they cut the piece exactly in half so i had two pieces "booked matched" like they do with a violin.i then took the two pieces and ran them on table saw to create a slot.glue up a 11/2" x 1/4" spline inserted and clamped.instead of putting a piece in front with grain going wrong way i took the hard course and did the same procedure.time is not even considered this is a 31bertram.next job was a cut out to recess the gauges under glass.for the top trim a made a one piece teak trim instead of the traditional ss trim many hours!!
Posted: Jan 5th, '08, 15:53
this is a scan (with coffee stain on picture) sorry only one i have this is in the building stage and did not put the flowscan trans. pressure gauge in when i took this shot.i sure you get the general idea with the roundover bit on every courner.-----------------bob
Posted: Jan 5th, '08, 20:31
I was wondering how you got all those perfect 1/2" glue lines in it. Then you sent the message about the scan.
Whose combo (port/stbd reading)gauges did you use?
Posted: Jan 5th, '08, 21:09
jp i used flowscan company gauges called twinscan 2". the gauges enaple me to make a smaller "underglass area" but also gave me another advantage; the indicater needle is red led set to the upper and lower limits you dial in and the needle will flash when limits are exceded.there also is a seperate back light for night running and a seperate wire to hook up to a bell,buzzer or whatever else you need to wake up and take action.the three led lights at the bottom of the glass area indicate forward,middle and stern bilge pumps.
pod
Posted: Jan 6th, '08, 02:45
by muddywater
Nice job on the pod!
The teak bezel was not something I had considered. I had spent quite a bit of time trying to find somebody that could machine stainless steel to make a bezel. It seems like most of the ones I have seen were anodized aluminum or chromed brass (like the ones sold here).
Thanks for the pic. It definitely helps to see it. I have one question about it though. Are the three round things inside the glassed area beneath the middle gauge air holes to prevent fogging or some kind of screws?
Posted: Jan 6th, '08, 07:53
the three round things are the led indicator lights i explained in the post.
