gel -kote
Posted: Aug 28th, '07, 20:37
by thereheis
i lost my gel-kote activater( hardner )... what can i use ???or should i use??
phil
Posted: Aug 28th, '07, 20:41
Phil,
MEKP, same as polyester resin, (which is what gelcoat is...). Mix ratio is 3% - 4% depending on ambient temperature.
gel -kote
Posted: Aug 28th, '07, 20:47
by thereheis
i figured as much ,but wanted to make shure..you about dried out up there? i am headed home tommorow for a week ,,,,gota bail the front yard,then back to port a . got the boat in the covered shed for awhile...waiting for good weather and the white run in sept,,,,thanks again....
phil
Posted: Aug 28th, '07, 20:50
Phil,
Nice & dry up here, only a couple of inches this month...
gel -kote
Posted: Aug 28th, '07, 20:55
by thereheis
dry down here also got lucky on the hurricane,,
phil
Posted: Aug 28th, '07, 21:35
by Marshall Mahoney
Also -- use the wax additive if the surface gelcoated is exposed to air. Avoid letting it cure in direct sunlite if possible. Both could lead to a tacky surface. I found using a little extra MEKP for a faster batch is better.
Posted: Aug 29th, '07, 08:35
by Mack
Pretty work.
Posted: Aug 29th, '07, 08:41
by Skipper Dick
Phil,
Outstanding job. One almost hates to get fish blood on the deck when they look like yours does.
Dick
Posted: Aug 29th, '07, 08:54
by ZeroCavity
Phil : Beutiful Boat !!!! Can you post more photos ? Will like to see your flybridge with more detail.
