Plexy Glass Windshield
Posted: Dec 5th, '24, 11:38
by lobo
Hello All, anyone know where I can get one? Thanks Russ-Rascal
Re: Plexy Glass Windshield
Posted: Dec 5th, '24, 12:38
by S Ritzert
make one, its not difficult.
Posted: Dec 5th, '24, 21:41
Is it the front or the side windows?
Posted: Dec 5th, '24, 22:08
by lobo
FBC, the windshield on the bridge .
Posted: Dec 6th, '24, 04:25
by franzmerenda
Posted: Dec 6th, '24, 10:49
by S Ritzert
I've tried to get udp plastics to make me windshields before. I have put in online order, and made numerous phone calls, and emails with zero luck. I finally got to the point that I had to learn how to make my own windshields. It is really not that difficult to do. I recently removed the windshields from my boat. The curved sections were made to curve by simply installing them. You can use the old ones for patterns. You can heat them with an oven, heat gun, or something to that effect and curve them too. The hardest thing for me to learn was drilling without cracking. The make bits to drill plexi with, or you can simply take a drill bit, and sharpen it like a pencil.
Posted: Dec 6th, '24, 13:56
To drill acrylic or polycarbonate grind the leading edge square so it scrapes the material rather then biting into it. Once it bites it pulled the drill like a screw and crack.
Posted: Dec 6th, '24, 22:15
I believe there is a thread somewhere on here about replacing the bridge windscreen. They are no longer available.
Try these folks:
https://www.procurveglass.com/
Posted: Dec 7th, '24, 07:57
by lobo
Thanks everyone for the info.
Posted: Dec 9th, '24, 15:08
by beachbum
Carl wrote: ↑Dec 6th, '24, 13:56
That's an awesome tip, will be employing in the near future! Thanks
Posted: Dec 15th, '24, 02:16
by Stav
To drill Plexiglas you need just an old drill bit for metals( no need to be new and very sharp) but also a piece of wood under the plexiglas .Dont try to drill it on the place, but mark first the points and after that put it on a table with a piece of wooden board under the Plexi.Hold them down tight and drill the Plexi till the drill bit reach the wood …
Posted: Dec 15th, '24, 16:50
Stavro, wouldn’t the drill bits for wood, with the pin in the middle and the three pointed sides be more appropriate for plexi drilling?
And how about cutting a line to separate two parts. There is a lot of vibration in this activity.
Posted: Dec 16th, '24, 08:08
by Stav
Till 10-12mm thickness of plexiglas we use to drill them with simple drill bit for metals .Either the plexiglas is cast or extruded..
Of course there are special drill bits for Acrylics with square nose but believe me you can do it with simple drill bit for steel… bu always have a wooden board under the Plexi..
For saw cutting Plexi you need a portable or table saw disk tool with carbon carbide teeth similar almost for fine cutting wooden panels , melamine boards ercr
You can use also a jigsaw but you need to have also the specific saw blade for plexiglas or other plastics.
With the right saw blade you can easily have a complex/curved cut..
Posted: Dec 16th, '24, 08:34
Thanks.
Do you think you can make me a plexi fairing for my 28 flybridge which is a bit complicated in that it has a bend in the middle, as well as downsloping sides?
I can measure the thickness. I may want it in its exact dimensions, or perhaps a bit taller so that it offers more protection. It has a light blue hue.
Where in Acharnes are you? I will have to go to Tyligadas one of these days to pick up some cushions, are you anywhere near them?
Posted: Jan 26th, '25, 19:37
by Ironworker
I think that I have an old B31 windshield if anyone wants it. Its free.
Posted: Jan 28th, '25, 10:17
by JeremyD
Not sure where I'd put it
Posted: Feb 20th, '25, 10:01
by lobo
Hello Ironworker, I'm interested in the windshield you may have. I'm in Florida , and was hit by Milton back in October. It ripped my hardtop off and broke my windshield. I'll pay you for it or make a donation to the site . Thank you in advance, although not sure how to do all this . lol My phone number is 732-689-3286. RUSS -RASCAL
