Oil cooler mounting bracket (454)
Posted: Jun 2nd, '24, 02:24
While replacing the raw water hose which goes from the oil cooler to the heat exchanger on my port engine, I discovered that the mounting bracket for the cooler is missing. The one on the starboard engine is bolted to the block with the lower-most of the three bolts which secure a the motor mount to the block. This means that in order for me to install the corresponding bracket on the port engine I will have to remove and replace one of the motor mount bolts. Is there a risk of throwing the motor alignment off if I do that?
