Thanks for the responses.
I am modifying a Bertram flybridge hardtop, (helm removed), front windshield, and side windows.
1. I am currently removing the wet balsa core and replacing it with CarbonCore Structural Plastic Honeycomb Panels. The balsa is 1.5" thick
2. Using the flybridge windshield it's about 5" taller than my current windshield, more headroom. I am removing about 8" from each side of the windshield (16" total) to reduce the width and fit in place of my existing windshield.
3. I will be using the flybridge side windows, only I will be reducing the length by about 18-20".
Add a box enclosure to store all the loose stuff from the helm area, VHF, etc. This is much easier to work with for wiring compared to home running everything through an aluminum support tube.
- Cockpit lights
- spreader lights fore and aft.
- maybe include structure in the aft area to allow attachment hooks for a cockpit shade?
- could use the top as a mount for navigation lights if you don't have the Bertram chock.
Yes, those are good ideas. Took the chock off, very old style unable to locate lens, replaced with anchor winch. Been thinking about where to put navigation lights.
Never had or used spreader lights, how useful are they?
Cockpit shade, yes I am adding attachments for shade, I have an aluminum radar arch I plan to run a shade to.
One of the things that came up has to do with the design so that you can have an enclosure made and installed without having any of the supports in the way.
1. I am planning on using the windshield and existing aluminum support in the front and cutting and moving the side fiberglass supports forward.
It is very important to have as little weight as possible that high.
1. Yes, I am trying to remove as much weight as possible, I am amazed at how heavy the flybridge top is.
