Bad storm in Corpus Christi TX
Posted: Jun 7th, '07, 20:01
Story of a local boat in Port Aransas Glad everyone is safe.
It wasn't us just a great story.
Our boat was the one that made the Corpus TV news. Here's our story.
We fish on a 33foot Bertram out of PortA a couple of times a week weather permitting . . . . a few posters have started threads below about what happened on Tuesday offshore and all I can add is that no matter what anyone tells you, it was probably worse that you'll ever believe.
We left the dock at 6:30 heading for Southern as we'd had a hot school-size wahoo bite for the last week hitting weed lines 30-45 miles out. Once we got to the buoy we found a 24ish center console tied up to the buoy and after a few trolls around without landing anything other than small bonita, we picked up and headed further offshore. 5 miles or so past Southern we found a decent rip and dropped back some big trolling baits as we continued out offshore . . . a few minutes later we picked up the storm heading our way.
My first thought was I hope the center console punched thru the squall line ok, and that was about all I had time to think as the damned thing was moving so fast it go on top of us 15 minutes later.
2 foot seas changed to 6 foot in minutes and we had water spouts ahead and to both sides. On board we had two licensed 6pack captains and myself - combined we've seen a lot of storms in the gulf and were't expecting anything different. We were wrong.
A few minutes in and seas were up to about 10 foot with 70+ mph winds. We put both captains on the bridge while I stayed on deck to watch things below. After about 20 minutes of pounding into the storm it lightened up briefly, but then it got worse and we were taking waves up over the bridge and I had to duck down below the overhang so as not to get washed overboard. We had water all over the deck but it seemed to be pumping out fine until I realized the water was actually not coming over the bow but thru the cabin. Not good.
I turned around and basically saw something that looked like someone had stuck 2 fire hoses into our v-berth and turned them onto full spray. I yelled at our second captain to come down and ended up having to grab his leg as of course he couldn't hear a freaking thing I was saying. Once he got down we both went up to see why we were taking on so much water and saw that there were docking lights installed in the bow of our hull . . . they had been punched out by the waves and we were basically going to go down bow first. We both grabbed pillows and life jackets to stuff into the holes but we were pounding so hard that we'd get knnocked off, take a face full of water, and then have to crawl back up to the holes. Since we really weren't able to help things I went thru the cabin and back up to the bridge to let the captain know we needed to call in a mayday to the coast guard. The work boat Southern Dancer picked us up and relayed our distress call to the CG and then immediately headed our way. They were an hour out and the CG chopper was flying a search and rescue pattern from a reported flare not too far from us so we informed them of our situation, gave our position and tried to save the boat. Meanwhile, the CG jet Falcon flew to us and circled to keep an eye on us.
We had one guy up in the berth doing his best to keep whatever pressure he could using pillows and such in the holes but it was just too rough to keep from being knocked away. The bilge pumps couldn't keep up with that much water so we started porpoising into the waves. I grabbed all of our EPIRB/rescue/flotation devices and headed on deck one more time. At this point I"d guess we were in 80mph straight line winds with water spouts everywhere and 12-16 foot seas. And oh yeah to top it off we were getting electric shocked by the water because we couldn't get to the switch box to turn off the electronics/lights/generator because the water was moving so fast thru the cabin.
Then it let up. Some. We were able to make a 180 and start to back into the storm and that's what saved everything. We pulled an intake hose off and stuck it into the engine compartment to suck that water out. THe seas kept coming down and we were able to keep backing in a circle until the CG helo got to us. They dropped a swimmer to us, dropped a pump, and stayed with us until we got the bow out of the water. About that point the Southern Dancer boat that relayed our initial call got there so the CG helo pulled off of us and went back for refueling. Awhile later we got both engines fired so we were able to run nose high at @ 13 knots in to PortA accompanied by Southern Dancer for the first 10 miles, and then the CG cutter Amberjack followed us all the way in to home.
Once home we went thru the standard boarding and one of the CG guys mentioned that we might have tried throwing one of our tarps over the bow and let the wave pressure fix it to see if that would have plugged the two holes. In another situation that might have worked, but in those seas any of us that even tried to walk out onto the bow would have been thrown overboard instantly. By the time it calmed enough to even attempt such a thought, we were already backing down.
Anyway, MANY, MANY thanks to our awesome coast guard and the Southern Dancer.
