BORG WARNER TRANS
Posted: Jun 7th, '07, 13:34
by Craig Mac
I have a transmission leak in the back of the tranny-I think it is a rear seal--also have my deck out as I am replacing the tank. How difficult a job is it to replace the seal now that i have good accessability?
Any special tools needed?
Posted: Jun 7th, '07, 13:52
easy take it out and have it rebilt, i belive theres a place in farmingdale every one uses
Posted: Jun 7th, '07, 17:25
Craig,
If you can slide the shaft back to get a socket and ratchet on, you can remove the output flange. You will have to make a tool to hold the flange by the bolt holes.
Replace the seal and the crush sleeve and torque to specs.
Posted: Jun 9th, '07, 14:51
by daydreams
I just changed my rear seal, took about 3 hours. Make sure you have enough room when you slide the shaft back . I had to use a socket and pipe wrenches, the ratchet would not fit. Good luck.
Posted: Jun 14th, '07, 09:34
by Craig Mac
Transmission is out and at the shop.
At this time was thinking of replacing rear motor mounts--any suggestions for new ones?
