Zero Cavity Pics
Posted: Jun 6th, '07, 20:36
Here is some eye candy of "Zero Cavity"
Did the final tweaking and sea trial today and I got 33.8 knots @ 3950 rpm with full fuel/240 gallons.
Instrument display pic is the Ray Marine e-120 interfaced to the Teleflex can buss system. I setup a full page display as an option for twin engine.
There is also a Teleflex display on a pull out panel on the bridge if you want to use the Ray unit on a full page GPS map or depth.
Additional is a Teleflex display in the stb engine room so you can monitor port and stb vitals while working on them without out having to jump to the bridge.
Both Teleflex displays are setup to show twin engine.
My part in this project was engine systems, controls, wiring and computers, startup, sea trials and tweaking various systems through out. Gen start up and load check.
Posted: Jun 6th, '07, 20:58
Bruce
Thats a great looking job............I'd be upset to see any fish blood or slime on that boat anywhere.
Simply beautiful
Harry Babb
Posted: Jun 6th, '07, 21:02
Amazing job. Question - how does one get on the f.b.?
zero cavity
Posted: Jun 6th, '07, 21:19
by thereheis
was wonderin the same ??
Posted: Jun 6th, '07, 21:20
Uv,
Gerry's got the pilaster steps.
Posted: Jun 6th, '07, 21:28
by thuddddddd
Awesome Bruce, just think what you could do with a worthy platform.............heck even a carver would be a upgrade
Posted: Jun 6th, '07, 21:35
by randall
nice!!
Posted: Jun 6th, '07, 22:13
well done!
Posted: Jun 6th, '07, 22:36
by Dave Kosh R.I.P.
Kudos Bruce. Super looking 31 and fast too... Dave K
Posted: Jun 6th, '07, 22:58
by Capt. DQ
Damn,
All these nice looking 31's sure make me feel like I need to go back to the drawing board. Great Job!
DQ
Posted: Jun 7th, '07, 00:18
by nic
Bruce,
Congratulations, beautiful job & result.
Could you pls provide the prop details?
Nic
Posted: Jun 7th, '07, 06:53
by ScottD
Really nice, the soft gauges might take some getting used to though. Bruce, where is the main panel you show located? Great job!
ScottD
Posted: Jun 7th, '07, 06:59
Nice clean job.
The panel looks like it's on the rope locker door. Is there an enclosure behind it?
Is this a FBC with the head removed, or a SF with a bulkhead added?
Where's the charger?
Posted: Jun 7th, '07, 07:22
Scott,
The panel is in the overhead, forward and center to the inside of the bridge facing. Regino Cabrera & crew did the vast majority of the work in Miami over about a 2 year span. The housing for the panel is glassed in & the overhead is raised about 3" over stock height.
Mike,
Gerry's "Zero Cavity" is a FBC & the head was moved to the V-bert configuration.
Posted: Jun 7th, '07, 07:25
thats purdy, makes mine look like, well i cant say it
Posted: Jun 7th, '07, 07:30
Wow. Beautiful!!!
Posted: Jun 7th, '07, 07:38
Very nice indeed, inspiring. I'm going home and break out the sander.
Posted: Jun 7th, '07, 08:19
by Vince Luciani
Wow! It truly is inspiring. Being in the middle of my own project, I have a great appreciation for the amount of hard work and skills (and time & money) needed to complete a project like that.
Good job Bruce!
Posted: Jun 7th, '07, 08:33
Amazing!!
Posted: Jun 7th, '07, 08:36
by capy
That is one sweet looking boat.......
You should be very proud.
Posted: Jun 7th, '07, 08:41
by ianupton
Gerry,
Nice looking boat! You should be proud.
How has the baby Bert been treating you?
Ian.
Posted: Jun 7th, '07, 09:54
Nic,
The wheels are 19x23 four blade Nibrils.
Posted: Jun 7th, '07, 09:58
by Craig Mac
Capt Pat,
HP, Trans ratio, and cruise speed would be helpful as well.
I am trying to compile a listing of repower results
Posted: Jun 7th, '07, 10:01
Spectacular is the word. Wow! Walter
Posted: Jun 7th, '07, 10:09
by Mikey
Gulp! Sure makes me jealous. Fabulous work.
Congrats, Bruce and to the Cabrera gang.
Whew!
Posted: Jun 7th, '07, 11:45
Bruce,
Are the cast, 90 degree, jacketed, water injection elbows Yanmar pieces?
Posted: Jun 7th, '07, 12:55
by Eddy G
Scot: The cast mixing elbows come from Yanmar with the engines and are normally attached directly to the turbo. Many applications require a custom made dry exhaust extension to gain the needed height above the waterline.
Eddy G.
Posted: Jun 7th, '07, 16:19
by Capt Dick Dean
Gerry, you make Dick Bertram smile.
Posted: Jun 7th, '07, 17:14
Props also have a medium cup.
Yanmar 6LP/315hp, 2:1 gear boxes.
Cruise speed can be anything up to 200 off the top.
24knots@3000 rpm
29knots@3600 rpm
Elbows are factory part.
Pulled the boat this AM but not before taking Tony, my shop mate out for a ride.
He's missed my last two 31 refits and is the only guy I know with arms big enough to have a 46' Bertram tatoo'd on his bicept with great detail.
Posted: Jun 7th, '07, 18:19
by RussP
Bruce, I bet Tony was grinning ear to ear.
RussP
Posted: Jun 7th, '07, 22:41
by Hueso
Capitan:
"Tremendo trabajo.........tienes que haber sacao'muelas como loco verdad?..........quedo preciosa.........ese barquito esta para correr todo el golfo y el este de Estados Unidos.....nuevamente felicitaciones......en relacion a la capota que le vayas a poner.......te recomiendo que vayas a la parte de fotos y busca la lancha No Respirar de Cesar Rivera......sleek, bajita y parece la original.....si quieres mas fotos de esa me avisas para que la veas en detalle......te lo recomiendo.........con esa capota se va a ver regia...."
TRANSLATION:
Great Job! and take a look at the fly bridge "roof"of the boat named No Respirar at the boat pics area....owner Cesar Rivera.....he designed it for his and it looks sleek......almost like the original one.....
Posted: Jun 8th, '07, 16:11
Alot del trabajo se ha hecho y su hora de golpear con el pie detrás para una cerveza o dos.
Posted: Jun 9th, '07, 09:39
by Hueso
Oh S#%^&! :shock: Bruce also knows Spanish......he the man, brooo!
Posted: Jun 9th, '07, 11:04
by GaryG
Very nice!
What is her cruse speed & fuel consumption ?
Installing a tower ?
Gary
Posted: Jun 9th, '07, 16:43
Gary,
Speeds are posted above.
No tower.
6LP's average 1 to 1.5 gal/mile at cruise.
Posted: Jun 11th, '07, 13:00
by ZeroCavity
Thanks to everybody for your nice coments ! Happy to share my project on this board for the past 2.5 years.
Posted: Jun 12th, '07, 09:21
by John Jackson
Beautiful! How did they do the front windows? Are they fiberglass frames?
Posted: Jun 12th, '07, 09:40
I totally encased the original aluminum frames with ~3/16" of fiberglass layup. Each of the three sections were done individually leaving the designed slip joint for re-assembly.
Revels were made with PVC Foam Board & were glassed in so that window glass and acrylic corners would be glazed in from the inside. Both the glass and acrylic were glazed in before taking the units back to Cabrera in Miami for installation on the boat. They were fiberglassed in place, faired & gelcoated for a seamless installation.
Interior flange moldings were fabricated and fitted in fiberglass sheet stock.
For the blow by blow progression see: Glassing Over Bertram 31' Front Aluminum Window Frames
Would I do this again? Probably not... Way too much time and agrivation.
Posted: Jun 12th, '07, 10:06
I think you were working on those when I stopped by your shop a couple of years ago. They did look complicated, but beautifully crafted.
Posted: Jun 12th, '07, 10:17
by Craig Mac
Capt Pat,
How many hours did this take?
How hard would it be to fabricate in stainless? I know the Bertram Riva 25's had stainless frames.
Posted: Jun 12th, '07, 10:28
by John Jackson
Capt. Patrick:
Wow! This just proves that when there is a will there is a way! How the heck did you come up with the game plan for that project? How many hours did it take? Is there any chance of the fiberglass delaminating from the aluminum? Any interest in doing another one?
I like the way the slightly larger frames look on the boat. I have redone my whole boat, but the windows, while I doctored them up to a point of acceptability, are not on a par with the rest of the boat. I had a welder fill in the holes on the curved window outside rims and that part came out pretty good. I bolted it from the outside, and the screw heads don’t really offend me, although the clean t-bolt from the inside way does look much better. To disguise the condition of the windows on the Hound I had my canvas guy make a front windshield cover that is clear with white over the frames and from a little distance it makes it look like the frames are a little fatter and I think it improves the appearance a little. Plus it has stopped all the leaks. Maybe I will take a crack at doing what you did over the winter. I will try and take some pictures of my "quick fix" and send it to you.
PS. Are you going to Atlantic City?
