Bert 25 Location of Main Fuse Block Fuses & No Power to instruments and ignition
Posted: Jul 4th, '22, 15:00
by chrisCA
Hi
I have a problem with my Bertram 25 1972 twin 165's
I lost all power to instrument panel and fuse blocks. I've been troubleshooting and found a wiring diagram.
Does anyone know if the location of these fuses that are on the AMM+
https://drive.google.com/open?id=1OZkeM ... p=drive_fs
Would it be at the back of the wiring harness or somewhere upfront. I can't seem to be able to find it.
Can you think of any other fuses that would cause a complete no power to front of boat? I have 12v at the starter solenoid
Re: Bert 25 Location of Main Fuse Block Fuses & No Power to instruments and ignition
Posted: Jul 4th, '22, 17:31
by Chanse
As you face the engine(s) you will see a large red button on the left side marked
CIRCUIT BREAKER, PUSH TO RESET. Try it.
Posted: Jul 4th, '22, 19:48
by John Swick
There should be a fuse/bus bar behind the helm console.
Access to that is thru the back of the bulkhead in the cabin.
Good luck.
Posted: Jul 6th, '22, 10:26
by chrisCA
Thank You guys.
I feel like such an idiot The breaker was right in front of me. Cooked up in dirt and grease.
I just had my morning coffee went down to the boat and just stared at the motors and haha there the breaker struck me in the face :-D
The are mounted backwards so the reset is facing back of the motors. Anyhow,
I reset it and it comes on for a few seconds, my sump pump comes on and than it trips. I'll work on it tonight. I suspect the sump pumps as the ignition was off when it tripped.
Any other short finding tips would be appreciated.
Much happier skipper Chris...
Posted: Jul 6th, '22, 21:05
Pump could be bad. I would discuss the float switch, wire the pump direct and see if it blows. If it does the pump is bad. If it doesn't get a new float switch.
Of course you could also have a bare spot on a wire touching and shorting out.
