Alternator slightly high output?
Posted: Jun 10th, '22, 20:04
One of my alternators is reading about 14.9 to 15.2 volts when charging.
I pulled the alternator and brought it to the local shop (old school shop) and they bench tested and under load and it never went over 14.5 volts. I swapped the alternators from port engine to starboard engine and the problem followed the alternator.
With that said I know the grounds and bonds are all good and all the connections are good as well. I am pretty meticulous on the electrical side.
I used a digital multimeter and checked at the battery terminals and also checked it at the charging post on back of the alternator and got the same results.
The old stewart warner gauges at the helm pretty much follow what the multi-meter is reading (maybe just slightly lower)
I guess I am wondering if my readings are just not totally accurate and should I leave it alone???
15volts might be a bit over for charging but not radically too much???
I dont know, any input is appreciated...
