What is this?
Posted: May 31st, '22, 17:27
by HotSpot
Every season, I come across one or two of these down near the drain plug.
I have yet to see one connected to anything. Where the heck are all these coming from? The bend makes it look like some kind of clamp. The look of it seems to indicate it is very old maybe original to the boat. Wiring clamps? Old rub rail fittings? Anyone know what these are?
Re: What is this?
Posted: May 31st, '22, 17:49
by scenarioL113
It is def a very old looking screw. If you keep coming across them then maybe one day the floor may drop or something....LOL
Re: What is this?
Posted: Jun 1st, '22, 06:37
Looks like a sacrificial anode for a curved surface; on a tube? on an exhaust?
Unless it's a bronze thing with salt...in which case science has no answer as of yet!!
Re: What is this?
Posted: Jun 1st, '22, 08:26
by HotSpot
Shined right up. bronze. There are some marks on the back that make it look like it was clamped to something metallic.
Maybe the Scenario's deck theory is close to being correct.
Re: What is this?
Posted: Jun 1st, '22, 08:45
by Raybo Marine NY
seems to be a saddle washer, where it was clamped to I cant help you with that
Re: What is this?
Posted: Jun 1st, '22, 12:37
by ktm_2000
I have the rear hawse pipes out of my boat when I went to gelcoat the gunnels, that piece looks a lot like the clamp which holds them down from the underside
Re: What is this?
Posted: Jun 1st, '22, 12:41
by Raybo Marine NY
ktm_2000 wrote: ↑Jun 1st, '22, 12:37
this would make sense!
Re: What is this?
Posted: Jun 1st, '22, 16:39
by HotSpot
You are on to something. I noticed that the port side corner hawse pipe was completely loose at the end of last season. Just held in by gravity. I assumed it was an adhesive failure and was ready to break out the caulk gun. If this is it, the other one is probably loose too or just hanging on by a couple threads. I’ll check it out when I get back to the boat. Thanks!
Re: What is this?
Posted: Jun 1st, '22, 18:50
Hawse pipe retainers
Re: What is this?
Posted: Jun 14th, '22, 14:24
by HotSpot
Hawse pipe clamps indeed!
Of the six total clamps, I had collected 5 over the years, and thankfully held on to them. Only one was still in place.
Thanks for the help, guys!
Back where it belongs...
Re: What is this?
Posted: Jun 15th, '22, 16:18
Locktite is your friend!
Re: What is this?
Posted: Jun 20th, '22, 09:14
by ktm_2000
I'm glad that I could help.
my favorite saying from one of my friends, "Every now and again, the sun shines on a Dog's Ass"
