scratchinging my head over domestic water pump issue
Posted: May 28th, '22, 14:28
Three years ago I upgraded Amberjack's salon. It was a wonderful improvement and for those contemplating that step I recommend it as a solid return on both financial and emotional investment.
While the salon was opened up I decided to proactively replace the Par Jabsco domestic water pump which was running fine but was 12 years old. We finished the project in early summer and took off on a four week trip into Canada. On the way home the new pump failed and I replaced it with the original pump which I had kept on board as a spare. After wrangling with the retailer and being told the carpenter would have to return the pump (he couldn't find his receipt) I took the hit and just bought another pump and installed it that fall. Next year on vacation this pump failed. Back in went the trusty original pump and now armed with a receipt I went to work on the pump retailer and then the manufacturer. The manufacturer's technical support person was a nice enough guy and helpful but after he put me through his paces he finally threw up his hands and sent me a replacement n/c. He assured me this pump had been tested at the shop before shipping.
This third new pump followed the same pattern: they run well at first, nice and crisp sounding. Then they start to labor a bit over maybe two or three weeks of use, then they start popping the breaker or if I keep resetting the breaker blow the fuse.
I can't figure this out and its driving me nuts. Now I have three almost new pumps sitting on my work bench and the (now) 15 year old same model pump happily ticking away on the boat.
I've confirmed free water flow to the pump intake, replaced the breaker and upsized the fuse from 7.5 amps to 10 amps (spec is an 8 amp fuse for a 6 amp motor). When I put a meter on the last pump as it was failing it quickly jumped to 10.5, 11, 12 amps. When I ran the pump on a hose direct from a bucket of water to confirm it wasn't a water restriction issue it started to jump violently as it approached pressure, then blew the circuit. This bucking likely happened with the other pumps but wasn't noticeable because those pump mounts were fastened down and the pump under the settee. I'm pretty sure it is wired in correctly and the factory tech says that reversing the wires wouldn't cause this issue anyway.
It almost feels as though the pump motors are defective and wearing out quickly, but three of them? Same for the pressure switch, three in a row can't be defective.
I'd really like to put the trusty old pump out to pasture and use one of these almost brand new pumps. Maybe I'm too close to this issue and can't see something obvious. Any ideas?
Two of the three new, failed pumps
Pump motor specs
One of the new pumps down in the "hole"
Pump motor specs
