Ignition system wiring
Posted: Aug 23rd, '21, 15:40
I'm getting ready to install the Delco EST system. My starboard engine has a Mallory distributor with electronic ignition conversion kit inside the distributor. Looking at the wiring in the attached picture, I have:
negative terminal:
- black wire goes to the distributor.
- dark brown wire, I assume, is for the tach
positive terminal:
- yellow wire is 12 volts from the ignition switch
- red wire to the distributor
- two light brown wires
Any ideas what these last two are for?
http://www.ipernity.com/doc/307687/50936024
negative terminal:
positive terminal:
