6BTA over heat issue
Posted: Jul 4th, '21, 13:38
Sorry for the redundancy, I posted this over on Boat Diesel.com and I'm trying to use the boat today and need help.
1993 250hp 6BTA, cpl 1322.
I lost an impeller the other day on my port engine. I Shut the engine down as soon as the alarm went off. Prior to this the engine was running great. Cruise would see about 190 degrees normally.
I replaced both impellers and went through the hoses and transmission cooler up to the heat exchanger, (my 250hp is fresh water cooled at the after cooler) thinking no way debris was going to get through the trans cooler. I found some chunks in the trans cooler and flushed all the hoses and cooler, including the hose up to the heat exchanger.
I checked the hull strainer and the seacock strainer which was all good.
Yesterday I went out and that engine started over heating at cruise. I would throttle back and the temperature would drop back 190.
I thought okay, there must be something in the heat exchanger blocking enough flow to overheat at higher RPM. This morning I took the exchanger apart expecting to find some blockage of some sort. Nope, it was clean. I inspected the tubes with a flashlight and they were all clear. I ran water from a hose through and the flow was good. So, I went back and pulled the hoses from the trans cooler again thinking I missed something but they were all clear.
I went out again this morning and the problem persisted. The funny thing is that the port engine was slower (not by much) than the starboard engine getting up to 190, and the EGT´s were lower. Got up to 200 degrees and throttled back. Got quite a bit of white smoke when at 200. It was smoke, not steam.
Engine coolant good, not using any.
What am I missing? Seems like anything outside those issues like a thermostat would be a highly coincidental thing.
