Stringer and fuel tank questions
Posted: Feb 10th, '21, 07:07
Hopefully someday soon I will have gained enough knowledge to contribute more than I ask
We are making progress still.... I put my wife Ashley to work.... One more deck stringer to remove today, then finish trimming the deck to hull connections.
I found one thing of concern.... I noticed a bit of bulging in the starboard inboard stringer. Tapping on it, it sounds solid, however I found the wood completely mushy for a few inches in every direction surrounding the drains in the stinger, and a bit of delimitation around the many unsealed holes for the deck stringers... After doing some reading here, it appears the consensus is that the strength from the stringers in in the glass, not the ply core? There appears to be no separation from the tabbing and hull. I am getting ready to start the glass work, should I just accept this or consider pulling stringers and rebuilding (I really don't want to do this $$)
I am considering replacing the current 165 gallon stainless fuel tank for around 220. I got a quote for $2K on a tar covered aluminum tank, I am also considering having an integral glass tank built or trying to find a glass tank built for the B31. What do you guys recommend?
Pics are below;
https://imgur.com/a/7Dy2IJx
Pics are below;
