Another Gelcoat Question
Posted: Nov 9th, '20, 17:56
Hey Guys,
Sanded the new exhaust on Shambala with 400 through 800 grit sandpaper over the weekend. Polished a couple of spots. Pretty happy with the results with one exception. Because I had to roll out the gelcoat in the boatyard, I knew there was likely going to be a thin seam on the inside radius of the exhaust and the very outside edge on the exhaust opening. Sure enough, by the time I got the orange peel sanded up I had sanded through a couple of spots on the exhaust.
My question is what the best method for covering this area would be. I am limited to rolling the gelcoat on in the boatyard (although I'm at the point where I just may sneak my HVLP gun in and shoot it anyway). Should I be trying to cover this with un-thinned gelcoat or can I use patch booster to thin and use a small paint brush to brush a couple of coats on the thin areas?
JohnV8r
JohnV8r
