Black smoke and slow acceleration
Posted: Oct 27th, '20, 14:53
Hi All,
I have a single Yanmar 4LHA STP ,
It takes 30 to 50 sec to get up on plane with a lot of black smoke,
runs fine at top end WOT is 3400,
the injectors were bench tested and all 4 popped at 3,000 lb ,
the boost pressure at the intake manifold is low during acceleration with the gage needle bouncing from 0 to 10 psi, at 3,400 rpm under way the boost pressure is 28 to 30 psi at the intake manifold,
I power washed and had the after cooler sonic cleaned twice , i can´t see through the tubes on the air side but I think its clean because I´m getting 28 - 30 lb of boost at WOT.
the turbo fins and bearing feel tight and spin freely and look ok some carbon build up, the turbo dump valve is free and seems to be working fine,
I changed the fuel filters and the air filter,
the fuel tank and lines look clean and are free flowing and the fuel is not at all cloudy.
the bottom of the boat isn´t dirty,
The exhaust drops 14 inches from the mixing elbow and seems to be clear with a small amount of corrosion on the mixing elbow,
I have the same prop that I had before the problem, It was a gradual not an abrupt change in the slower acceleration.
It has a Yanmar fuel pump delivering 20 lb to the injector pump, I measured it after the filters,
The Yanmar injector pump has a diaphram governor with an air line running to the intake manifold being adjusted by the boost pressure witch in turn regulates the amount of fuel delivered to the injectors,
Has anyone had experience with these pumps ???????
Any help would be appreciated
Steve
Steve
