gelcoat over raw marine ply?
Posted: Oct 13th, '20, 09:54
Hi All,
I was planning out how I would mount all the wiring inside my doghouse. I have some scrap 13mm marine plywood and was going to bond it in, one piece of each side of the inside of the doghouse under the helm area. The area will be fairly protected but may get spray over time as the deck is washed down. At some point I will get a door like this one made to keep most spray out https://www.boatoutfitters.com/lift-out ... h-toe-kick.
I would also like to keep the wiring area clean and neat so I was thinking of having a gelcoat surface and was wondering if I could get away with skipping a few steps of glassing with 1.5oz mat and fairing.
Your thoughts? am I going overkill, maybe just sand and put bilgecoat paint on the board?
