Intake manifold gasket
Posted: Oct 11th, '20, 15:51
It looks as though I have a break in the intake manifold gasket on my port engine between the #3 and #5 cylinders (see the picture below). The engine seems to be running normally - not overheating, no apparent power loss, no loss of coolant. What is the best way to check that area for a vacuum leak?
From the pictures of the cylinder head that I can find online, it does not look like this area has any openings which need to be sealed. Is that a correct assumption?
http://www.ipernity.com/doc/307687/50410338
