Bertram 28
Posted: Dec 9th, '19, 09:38
by Jrssndb1
Rebuilding 1979 28, boat has mercy 228hp engines, the carb intake wedges appear to be missing. Did this application come with wedges?, where might I find them, nla.
Re: Bertram 28
Posted: Dec 9th, '19, 13:47
by Donmystic1
What is the down angle of the engine. I have a 1986 and no wedges.
Re: Bertram 28
Posted: Dec 9th, '19, 14:24
by Jrssndb1
It appears to be 15 degrees
Re: Bertram 28
Posted: Dec 9th, '19, 21:48
by Donmystic1
I don’t think that you need wedges for that little angle. See what others say about your vintage boat and engines
Re: Bertram 28
Posted: Dec 10th, '19, 08:05
by Captmas
Ours is a 76’ Bert 28 with the same motors and it does have wedges ....you may find them at Summit Racing
Mike
Re: Bertram 28
Posted: Dec 10th, '19, 12:42
by Jrssndb1
Thanks everyone for the info!!
Re: Bertram 28
Posted: Feb 13th, '20, 17:55
by bertram 20
i have a 1986 28 FBC with twin merc 350s and both engines have wedge plates under carbs i recently put edelbrock carbs which i love and was looking for a spare set of wedge plates to modify because the edelbrock would not work properly with out opening up center of wedge plate i did find a pair at some boat junk yard and they were the proper angle degree so i have a set for rochester carbs and the ones i modified for the edelbrocks
